Home > Maintenance & Mods (L405) > What Battery Charger?
Page 2 of 3 <123>
Gremlin500
Shocked
Oh dear no, not on one’s dearly beloved FFRR, surely one needs to be terribly unobtrusive and OEM dahlings! Laughing “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #684481 31st Jan 2024 11:01pm
Tiny Timmy
MrWold wrote:
I have jubilee clips on the posts with the eyelets on the tightening screws
Really how does that work ? Can you get a pic for me if possible?
TT
Post #684491 1st Feb 2024 6:52am
ttrw2
I use an Aldi Smart charger on all on my cars - it’s a decent bit of kit made by Meridian. Usually £12.99, think it’s same as Ctek underneath.
https://www.aldi.co.uk/auto-xs-car-battery...0347442700
Post #684493 1st Feb 2024 7:30am
MrWold
England 2014 Range Rover Autobiography SDV8 Barolo Black
Expecially for TT. You were lucky as I needed to charge it today.
I bought a 6.3mm eyelet connector (smaller than standard) and the jubilee clips look like 7-9mm and some longer screws (M something and length of something) and it looks like a washer on there as well.
Amazing how the Sunny Sussex Sun shows up each tiny grain of dust/sand in photos. Chris
2014 FFRR 4.4 SDV8 Autobiography Barolo Black
2012 RRS SDV6 HSE Baltic Blue
and before I saw the light:
2011 Suzuki Grand Vitara SZ5
1998 Ford Mondeo V6 Ghia X
1990 Citroen BX GTi
1973 Triumph GT6
Post #684503 1st Feb 2024 10:18am
Gremlin500
Hi TT,
I’ll try to get a pic of my “stealth” version today… “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #684504 1st Feb 2024 10:30am
Tiny Timmy
Thanks Chris , I see now, maybe easier.
Never trust a camera Razz Thumbs Up
Post #684505 1st Feb 2024 10:34am
Tiny Timmy
Gremlin500 wrote:
Hi TT,
Great thanks
Post #684506 1st Feb 2024 10:37am
Gremlin500
Hi TT, here you go:
Post #684527 1st Feb 2024 1:47pm
Tiny Timmy
Excellent thanks Gremlin , I'll have a look, I thought I had plastic under my posts ?
I'll have another look
Post #684528 1st Feb 2024 1:50pm
Gremlin500
The Negative post can be undone completely to fit the ring for the CTEK lead.
As I said above, you cannot unscrew the positive post (don’t try!), the entire box can be removed by undoing the 10mm bolt to the right of the terminal box in the pic and carefully prising out the plastic plug (to the left of the box). There is just sufficient slack to flip the box over, and all will be revealed!
You should really disconnect the Battery/batteries, before doing stuff like this, -unless you’re a Gremlin Rolling with laughter “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #684529 1st Feb 2024 1:53pm
Matt Buckland
United Kingdom 2017 Range Rover Autobiography TDV6 Santorini Black
Awesome. Thanks Gremlin. I have been puzzling for a while how to hardwire a flying lead for my Noco charger to the posts. That’s a weekend job you’ve just created for me 😂 L405 2017 TDV6 AB
Previous toys:
4.4 TDV8 Westminster. Santorini Black
1976 Lightweight
4.0l P38
2 Disco 3s
Jaguar XJ6 (X350)
Jaguar XJ8 (X308)
Jaguar XK
Jaguar XK8. Confirmed JLR nut.
Post #684532 1st Feb 2024 2:00pm
Tiny Timmy
Great thanks again Gremlin, I'll have a look and go from there
TT
Post #684539 1st Feb 2024 3:01pm
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
This was sent to me from the company that I bought my battery from when mine would not engage the stop/start.
It appears that the car may not be used enough, leading to a slow degradation in the capacity of the battery. All modern vehicles have on board equipment that have a constant drain on the battery (luxury vehicles with more options are the worse) so a vehicle needs to be used regularly for a reasonable time in order to keep the battery in good condition.
Leaving a vehicle standing for extended periods of time, or even using a vehicle once a week or multiple times but only for short runs is not enough, as you are taking out more than the cars alternator is able to put back into battery the during the time it is being used. The longer period this happens over, the more irreversible this will be leading to early failure.
Do you have a charger which is 7Amp or 10Amp with an AGM setting ?
Or could you tell me which charger you have ?
To recharge an AGM battery the charger needs to get to around 14.7V and needs to be of a reasonable size as well, for your battery I would say 7A and above.
What you have described to me does not appear to be a manufacturing fault, but simply a result of usage.
If a battery has a fault such as an internal short or bad cell, you would loose two volts so the battery voltage would simply be knocked down to 10.2V or there abouts and would not be able to recharge. Also it simply would not start the vehicle before or after charging.
Just to put things into perspective if you have a slow/trickle charger, it would be about 1Amp output, this would take 5 days to recharge a flat battery fully, if indeed it was able to get to the 14.7V before any internal timer would shut the battery off.
If the car simply doesn't get used often enough, periodic recharging would help maintain the battery and extend its life.
We have customers that simply do not use their car enough and do not have the ability to recharge due to where the car is parked etc, and they have accepted the battery will need to changed much more regularly than someone who uses their car an average amount (circa 10,000 miles a year)
Of course if you would like us to recharge and double check your battery for you, that isn't a problem, but you would need to leave it with us for a couple of days at least in order to charge it fully before testing.
Regards,
DENKA
Andrew Tan
a.tan@denkapower.com
DENKA
Offic 2017 SDV8 4.4 silicon silver AB
2012 TDV8 4.4 Stornaway Grey AB
2011 TDV8 4.4 Buckingham Blue
2012 VW V6 3.0 Tougreg
Post #684542 1st Feb 2024 3:44pm
Gremlin500
You’re all going to kill me for this Laughing
The eagle-eyed among you will have noted that there are TWO pairs of wires attached to my posts?
One pair for the CTEK remote socket hidden in the lower front grille, but what’s the other pair for? Whistle
Well, following on from the famous “regeneration trainee nerd” thread and my experience of the excellent Vgate OBDII dongle to monitor live DPF Soot, I bought THIS: Rolling with laughter
This is great, as you can monitor the battery from inside the house, with the car all locked up.
The first graph is without CTEK, then engine start, then plug in CTEK. The second graph is first thing in the morning with the CTEK plugged in all night. Current draw is tiny. So far, so good!
Got mine from the official Vgate store on AE. Thumbs Up
I can see a few additions tonight to the “drunken purchases” thread! Rolling with laughter Rolling with laughter Rolling with laughter “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #684543 1st Feb 2024 3:48pm
Gremlin500
@Tinman:
I repeat what I said above: the faster you charge a battery, the shorter its life will be, and a 7A charger is a bit overkill, the CTEK MXS 5.0 manual states its good for batteries up to 160Ah for maintenance, so why go bigger?
Of course, the battery companies WANT you to push in a lot of amps, -so they can sell you a new battery! Anyhow, most of us are only “topping up” rather than needing to quickly charge a fully depleted battery, so maybe even 3A is OK especially if you have all night….
Agreed the “use it or lose it” rule applies, so the best alternative it to keep it plugged in to it’s “heart monitor” (CTEK) as we call it! Rolling with laughter “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #684546 1st Feb 2024 4:05pm
Page 2 of 3 <123>
