Home > Maintenance & Mods (L405) > Halford 'OAT' coolant
Bikeracer
United Kingdom 2014 Range Rover Vogue SE SDV8 Nara Bronze
I have had the low coolant light come on on a cold start this morning and not show when the engine is warm.
Assuming it only wants topping up when the engine is cold, I wonder if the Halfords 'OAT' coolant would be suitable.
Cannot find Havoline XLC locally to Newark
Post #682415 11th Jan 2024 1:03pm
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
I was advised not to mix and stay with JLR coolant if thats whats in it, thats my only advice.
Post #682424 11th Jan 2024 1:55pm
Bikeracer
Thanks, I've since found some 'Comma" brand at a local factors and it says in the description it's suitable for the L405 engine.
Probably end up on Amazon for the Havoline XLC just to be safe.
Post #682429 11th Jan 2024 2:13pm
fisha
You could just top it up with water initially. That wouldn't make much difference to the dilution factor of the coolant / antifreeze. V8 or else ...
Post #682431 11th Jan 2024 2:21pm
ChrisJC
United Kingdom 2014 Range Rover Vogue SDV8 Aintree Green
I've got a lot of Halfords OAT in mine... I hope it's OK.
Chris. L405 - 4.4SDV8 Vogue
P38 - 4.6V8 HSE
Land Rover series IIA V8
Post #682452 11th Jan 2024 7:27pm
fisha
Likewise. To me, as long as you're not mixing the wrong type of coolant ( blue / green stuff ) into the system, then generally it should be fine. I cant think of anything particularly special about the 4.4 compared to other engines which use OAT ... at the end of the day its a ford block. I cant see Ford developing something outwith the normal envelopes of standard cooling fluids for domestic engines. V8 or else ...
Post #682456 11th Jan 2024 8:11pm
