![]() | Home > Maintenance & Mods (L405) > Halford 'OAT' coolant |
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1435 ![]() ![]() ![]() |
I was advised not to mix and stay with JLR coolant if thats whats in it, thats my only advice. |
Bikeracer Member Since: 24 Aug 2023 Location: Newark Posts: 10 ![]() ![]() ![]() |
Thanks, I've since found some 'Comma" brand at a local factors and it says in the description it's suitable for the L405 engine.
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1416 ![]() ![]() |
You could just top it up with water initially. That wouldn't make much difference to the dilution factor of the coolant / antifreeze. V8 or else ... |
ChrisJC Member Since: 14 Sep 2023 Location: Northants Posts: 132 ![]() ![]() ![]() |
I've got a lot of Halfords OAT in mine... I hope it's OK.
Likewise. To me, as long as you're not mixing the wrong type of coolant ( blue / green stuff ) into the system, then generally it should be fine. I cant think of anything particularly special about the 4.4 compared to other engines which use OAT ... at the end of the day its a ford block. I cant see Ford developing something outwith the normal envelopes of standard cooling fluids for domestic engines. V8 or else ... |
