Home > General (L405) > 2015 L405 Vogue SE - Heater ??? |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3164 |
if it's a diesel it will definitely have a FBH (fuel burning heater)/Aux heater - they all do as standard. It is used primarily to heat the engine/coolant on starting as the 4.4 TDV8 is a cool running engine. However if you have a receiver in the boot (not sure about the L405, but in the 322 it's on the right) then you do have the facility but it will need a transmitter (91 version?).
1st Dec 2023 1:09pm |
Iceboy74 Member Since: 20 Sep 2023 Location: Berkshire Posts: 20 |
Thanks DB, I will have a search.
1st Dec 2023 1:11pm |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1371 |
It'll likely have an FBH, but it doesn't put its heat into the cabin air directly. As above, it heats the coolant, which will take time to get to a temp where it'll start putting noticable heat into the cabin through the heater matrix.
1st Dec 2023 1:18pm |
OK Fisha. |
1st Dec 2023 1:19pm |
BigJock2005 Member Since: 09 Dec 2023 Location: Bucks Posts: 15 |
I believe that's to reduce cabin noise and for reduced emissions. Gotta save the planet and all that. In a V8 strikes me about as impactful as a pea on a mountain. |
27th Dec 2023 6:39pm |
