Home > General (L405) > 2015 L405 Vogue SE - Heater ???
Iceboy74
United Kingdom 2015 Range Rover Vogue SE SDV8 Santorini Black
Hi All,
I know its a bit of a first world problem but does my car have an auxiliary heater? I think that is what its called? My S-Class would blow hot air within 20 seconds from a cold start.
Let me know if I have to press something LOL.
IceBoy
Post #679210 1st Dec 2023 1:01pm
Dolphinboy
United Kingdom 2015 Range Rover Autobiography SDV8 Baltic Blue
if it's a diesel it will definitely have a FBH (fuel burning heater)/Aux heater - they all do as standard. It is used primarily to heat the engine/coolant on starting as the 4.4 TDV8 is a cool running engine. However if you have a receiver in the boot (not sure about the L405, but in the 322 it's on the right) then you do have the facility but it will need a transmitter (91 version?).
Do a search on here and there is lots of info on FBH. Thumbs Up
Post #679211 1st Dec 2023 1:09pm
Iceboy74
Thanks DB, I will have a search.
IceBoy
Post #679212 1st Dec 2023 1:11pm
fisha
It'll likely have an FBH, but it doesn't put its heat into the cabin air directly. As above, it heats the coolant, which will take time to get to a temp where it'll start putting noticable heat into the cabin through the heater matrix.
Mine doesn't blow hot hot air within 20 seconds that for sure, but it begin to put out warmed air fairly quickly. Plus, I've found that the climate settings are generally set to be quite slow/gentle to respond if left to their own devices. V8 or else ...
Post #679213 1st Dec 2023 1:18pm
Iceboy74
OK Fisha.
Post #679214 1st Dec 2023 1:19pm
BigJock2005
United Kingdom 2012 Range Rover Autobiography Black 5.0 V8 Sumatra Black
I believe that's to reduce cabin noise and for reduced emissions. Gotta save the planet and all that. In a V8 strikes me about as impactful as a pea on a mountain.
Post #681264 27th Dec 2023 6:39pm
