Home > Technical (L405) > Gearbox not calibrating
LJMorrick
South Africa
Hi
Please everyone bear with me if I don't give enough detail but I will happily get anymore information for someone who can assist me.
To be succinct: Our gearbox won't calibrate after having the transmission control module replaced.
Can anyone assist? Dealer doesn't know what to do.
Post #673119 11th Sep 2023 11:30am
Mikebob
South Africa 2007 Range Rover Supercharged 4.2 SC V8 Java Black
Why was the TCM replaced ? What car ? What box
Post #673135 11th Sep 2023 4:55pm
baz000000
England 2016 Range Rover Autobiography SDV8 Loire Blue
If the box won't leave Park then it is likely to be an immobiliser input preventing the car moving and it would need code matching to allow gear selection. If the box is running through gears then that'll be something else entirely.
There are a plenty of BMW TMS videos online you could wade into as the ZF8 box is common with JLR.
Post #673166 11th Sep 2023 10:45pm
LJMorrick
South Africa
it is a 2014 L405 Range Rover Vogue SDV8.
The Transfer case is what actually is not wanting to calibrate.
We had the transmission control module replaced as there was a circuit actuator stuck in open.
Dealer is perplexed as to why it's not calibrating as it has everything it needs to.
Post #673276 13th Sep 2023 2:39pm
try putting it in nuetrel with the park brake on.. ... - .- -.
Post #673277 13th Sep 2023 2:41pm
Phoenix
I'd be checking all the plugs are pushed home properly on the transfer box, the earth strap is connected and the harness isn't trapped / damaged. I've had problems before with transfer box calibration after repairs, it's always been either a connection issue or the position of the clutch actuator in a implausible position. It'd probably be worth checking the relevant fuses in case something was shorted out during the repair operations.
Post #673312 13th Sep 2023 8:48pm
