![]() | Home > Technical (L405) > Gearbox not calibrating |
Mikebob Member Since: 10 Jun 2019 Location: Pretoria Posts: 10 ![]() ![]() ![]() |
Why was the TCM replaced ? What car ? What box |
baz000000 Member Since: 01 Apr 2022 Location: Shropshire Posts: 141 ![]() ![]() ![]() |
If the box won't leave Park then it is likely to be an immobiliser input preventing the car moving and it would need code matching to allow gear selection. If the box is running through gears then that'll be something else entirely.
LJMorrick Member Since: 11 Sep 2023 Location: Johannesburg Posts: 2 ![]() ![]() |
it is a 2014 L405 Range Rover Vogue SDV8.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35482 ![]() ![]() |
try putting it in nuetrel with the park brake on.. ... - .- -.
I'd be checking all the plugs are pushed home properly on the transfer box, the earth strap is connected and the harness isn't trapped / damaged. I've had problems before with transfer box calibration after repairs, it's always been either a connection issue or the position of the clutch actuator in a implausible position. It'd probably be worth checking the relevant fuses in case something was shorted out during the repair operations. |
