![]() | Home > Maintenance & Mods (L405) > ARC/ACE issues... New front and rear pipes |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8533 ![]() ![]() ![]() |
Rear pipes delivery date keeps getting pushed back, now saying 3rd Oct, we're away till mid December a week after so I hope it turns up soon... |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16336 ![]() ![]() ![]() |
Oh no, that’s a pain Peter… So much is on back order at the moment! Annoying to say the least! |
It sure is, I'm beginning to have withdrawal symptoms...... |
Well I went to pick up the rear heater hose/pipe as the ARC pipe still hadn't turned up and it was something that could be done in the meantime...
With an operating pressure of 180Bar, I wouldn't be using copper pipe or standard compression fittings, there are plenty of options for that size and pressure though. |
David, Robins a really nice guy, come down for a trip in your new one... |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1810 ![]() ![]() |
We've one in tomorrow with a "hydraulic leak" and red warning on the dash
10L steel compression through fittings are about £3.50 each, rated to 500Bar. 10mm OD 1.5mm wall steel tube is about £6 a metre. Given the cost and increasing scarcity of supply, I may well 'roll my own' when the time comes - Pete, can I grab the end fittings off you? there only needs to be 150-200mm of tube beyond the fittings to be useful. |
Mikey... weird, it was showing it was supposed to be with the distributer tomorrow and with them on the 4th or 5th... it's been put back and back... maybe a new load has come through.... oh well, got them both now, and the heater pipes.... |
That's fine mate, I can always braze some new stubs into the end fittings, I'm thinking of making the ends up ahead of time so if/when the day comes, it'll just be a case of forming some tube to fit and nipping up a few compression couplers. |
Some good progress today....
Cracking job there!
A few points for anybody doing this in future,
Nice job there Pete, the ground stud is an annoyance but better now whilst you have good access & time than whilst you're driving at night in the rain... |
