![]() | Home > Maintenance & Mods (L405) > ARC/ACE issues... New front and rear pipes |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8520 ![]() ![]() ![]() |
Rear pipes delivery date keeps getting pushed back, now saying 3rd Oct, we're away till mid December a week after so I hope it turns up soon... |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16334 ![]() ![]() ![]() |
Oh no, that’s a pain Peter… So much is on back order at the moment! Annoying to say the least! |
It sure is, I'm beginning to have withdrawal symptoms...... |
Well I went to pick up the rear heater hose/pipe as the ARC pipe still hadn't turned up and it was something that could be done in the meantime...
![]() Then finished and hopefully it will last a bit longer... ![]()
If anyone is wondering, the pipe is exactly 10mm OD so standard plumbing fittings and 10mm copper pipe would be able to be used for localised repair...
So back down the garage tomorrow to put it all back together... ![]() __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click for Project Fatty off roader- |
With an operating pressure of 180Bar, I wouldn't be using copper pipe or standard compression fittings, there are plenty of options for that size and pressure though. |
David, Robins a really nice guy, come down for a trip in your new one... |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1804 ![]() ![]() |
We've one in tomorrow with a "hydraulic leak" and red warning on the dash
10L steel compression through fittings are about £3.50 each, rated to 500Bar. 10mm OD 1.5mm wall steel tube is about £6 a metre. Given the cost and increasing scarcity of supply, I may well 'roll my own' when the time comes - Pete, can I grab the end fittings off you? there only needs to be 150-200mm of tube beyond the fittings to be useful. |
Mikey... weird, it was showing it was supposed to be with the distributer tomorrow and with them on the 4th or 5th... it's been put back and back... maybe a new load has come through.... oh well, got them both now, and the heater pipes.... |
That's fine mate, I can always braze some new stubs into the end fittings, I'm thinking of making the ends up ahead of time so if/when the day comes, it'll just be a case of forming some tube to fit and nipping up a few compression couplers. |
Some good progress today....
Heater pipes replaced as well, pretty straightforward job.... it goes from the front of the offside wheel arch to the rear of the nearside... The old pipe was in a sorry state under the insulating sleeve that is just loose fitted, I sealed up the ends of the sleeve with some self amalgamating tape, hopefully this will keep the salt out and stop the corrosion.. Then dropped the body onto the rear subframe and bolted it up with the newly powder coated fittings, insulated from the aluminium with some 1mm silicon sheet Pipes, wiring, brake pipes, airlines etc reconnected...
And it's starting to look like a Fatty again instead of just a shell.... I had to leave then for an appointment but my mate Colin had a few spare hours so he carried on, he's got the front pipe and anti roll bar fitted, just needs buttoning up in the morning, I'm going to clean up the earths behind the covers in the front wheel wells, and clean up that rusty bracket, pre-empt any future issues.... then we should be close.... __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click for Project Fatty off roader- |
Cracking job there!
A few points for anybody doing this in future,
Took it for a 5mile drive, provoking the ARB's to work and everything seems fine, no fault showing at all and seems to drive spot on, I presume if there is some residual air in the system that it will self bleed, I'll keep a close eye on the level... The front off side ground connection cleaned up well, there was a minute amount of corrosion, all cleaned and treated with Corrosion X heavy duty. There is also one under the nearside wheel arch liner as well, seen here with two connections and looking in very good condition... I put the spanner on it and started to turn it and with no pressure at all it fell off all on it's own.... You can see in this photo that the whole stud had corroded through, there was less than 1mm square of clean aluminium... ![]() I replaced the ground point with a self drilling and tapping hex head bolt which should do the job fine I had gravity bled the rear callipers as I always like to start with the least invasive form of bleeding but there is still some air there as the pedal is fractionally down from before... I also have to remove the side steps, fit the under sill covers and refit the steps, I dare say doing some more rustproofing and cleaning up so left it for today as we have visitors and birthdays to celebrate this weekend, work will resume on Tuesday... Pete __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click for Project Fatty off roader- |
Nice job there Pete, the ground stud is an annoyance but better now whilst you have good access & time than whilst you're driving at night in the rain... |
