![]() | Home > Maintenance & Mods (L405) > ARC/ACE issues... New front and rear pipes |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8532 ![]() ![]() ![]() |
Thanks lads,
Oh, and if anyone is reading this and going to do theirs it took about 1 1/2 ltrs of Cold Climate power steering fluid to top the system back up.... |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1461 ![]() ![]() |
Great job. Good effort. I’d just need to figure out to lift mine without a post lift. V8 or else ... |
I don't think it would be easy on the floor but take your time and plan well and it should be doable... the rear pipe runs between the floor and the rear, nearside, running board mounting bracket so you need to support the fatty somewhere other than that jacking point. The front pipe needs some height under the car to fit the pipe through without removing the front subframe....
horse86 Member Since: 09 Dec 2014 Location: PA Posts: 863 ![]() ![]() ![]() |
so all the bubbles in the rez didn't cause an issue i.e air being in the system? 2014 FF Autobiography 5.0 SC 2008 FFRR (sold) 2008 BMW M5 |
NoHandSignals Member Since: 28 Aug 2023 Location: MI Posts: 28 ![]() ![]() ![]() |
Pete, any chance of some additional insight here with this front ACE pipe removal and refit? I have my front ACE pipes disconnected from the roll bar, and have undone the two joints midway across the front cross member, but can't figure which way to feed the old pipes out and new ones in without them getting stuck? TIA |
No, it seems to have self bled itself after a short while... there must be some small amount of return like most hydraulics. The car will throw up a "car leans too much" fault if it's not working so it must be OK... Nohandsignals, It seemed obvious when doing it...!!! you have to persuade the pipes to go in, they will bend quite a bit before they are permanently out of shape, you need a bit of mechanical experience, you have to know what you can and can't get away with. It's not really an easy DIY job.... I've slept a lot since!!! I think I took some suspension arms off and a few other bits.... I didn't do a full write up as it was replaced rather quickly as it had been taking a lift up for three weeks while the parts arrived and it takes time to photograph every step, sorry.... Pete __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click for Project Fatty off roader- |
Thanks, Pete. Maybe I’ll try taking the right front strut out to see if that gives me room to rotate the pipes out from the crossmember where I’ve disconnected the two right hand lines. |
Stick Legs Member Since: 16 Sep 2021 Location: Somerset Posts: 32 ![]() ![]() ![]() |
A thoroughly useful thread. Thank you. |
Just wanted to follow up and say once the right front hand strut was out, the right hand side of the front ARC pipe was “easy” to rotate into place and reconnect to its joint midway across the top of the subframe and at the ARC bar itself. FYI, I fed the ARC pipe up from under the car near the ARC bar itself, out into the RH wheel well via the gap between the sub frame and the chassis leg, and once it was through that gap, it was easy to rotate the pipe rearward, back towards the rear part of the front subframe, and remake the connection there. |
A bit more info on doing the rear pipe with the car on the floor....
