Home > Maintenance & Mods (L322) > MOT Advisory on Brake pipes
Page 3 of 3 <123
SamThomas
United Kingdom 2003 Range Rover Vogue Td6 Baltic Blue
Cam-Tech-Craig wrote:
Exactly Peter... 2000PSI or maybe 2500 in an emergency, when you're the size of us lumps Peter!
Whistle Whistle Whistle
Thanks for the info' guys - I had no idea it was that high.
Post #672409 31st Aug 2023 11:34am
I'll have you know I resemble that remark.... Rolling with laughter Pete
Post #672431 31st Aug 2023 4:19pm
Old-un
United Kingdom 2011 Range Rover Vogue 4.4 V8 Causeway Grey
Just had a reply from the garage that passed my mot with an advisory on rear brake pipes corroding following my request for a quote to replace them.
They said " we're very busy at the moment but don't worry 'cos we're sure they will be ok untill your next mot and we will have a look then" ????
Really, the mind boggles at the incompetence of these people, booked it in elsewhere. RR owner
Post #672522 1st Sep 2023 10:42pm
Rolling with laughter Rolling with laughter Rolling with laughter Thumbs Up
Post #672528 1st Sep 2023 11:42pm
SamThomas
Bet they won't put that in writing !
Post #672533 2nd Sep 2023 8:38am
Old-un
Rear brake pipes done at Henshall Engineering, Chelford, Cheshire+oil and filter change.
Very happy with job and cost. RR owner
Post #675190 9th Oct 2023 8:33pm
D3Jon
A wise choice Old-un! Thumbs Up Very Happy
I found on both my L322's that when the steel brake pipes were seen to be corroded where they connect to the rear flexi's, i.e the visible bits in the rear wheel arch that a MOT tester sees, they were in fact very bad at each and every pipe clip within the hidden part behind the cill panels, along the length of the nearside cill.
I was quite shocked TBH, it would seem that the pipe clips hold moisture against the pipe itself, causing local corrosion. Nothing to do with mud / salt as far as I could tell, as it was pretty clean in there on both cars. It seems to be just the way the clip connects / interfaces with the painted steel pipes from the factory.
I'd say that every just about every L322 should by now have had both the front to rear and cross axle steel brake pipes replaced - seeing as the *EDIT* youngest *EDIT * L322 is now 11 years old!
Jon 1992 RR Classic 3.9 efi Vogue
2014 Disco 4 HSE
Both my fatties now gone...
Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus)
Post #675195 9th Oct 2023 9:18pm
AJGalaxy2012
Shouldn't that be the youngest is now 11 years old?
Kunifer 10 is the answer to the brake pipe problem. BMW i3 Electric Car
2006 VW Touareg 3.0 TDi V6
Post #675219 10th Oct 2023 5:06am
D3Jon
Oh yeah, good spot ! Thumbs Up 1992 RR Classic 3.9 efi Vogue
2014 Disco 4 HSE
Post #675226 10th Oct 2023 9:41am
Page 3 of 3 <123
