Home > Maintenance & Mods (L322) > MOT Advisory on Brake pipes
Page 2 of 3 <123>
JMC
I've just had my MoT and the front brake lines were an advisory.
Repair as soon as possible (minor defects):
Nearside Rear Registration plate lamp inoperative in the case of multiple lamps or light sources (4.7.1 (b) (i))
Monitor and repair if necessary (advisories):
Brake pipe corroded, covered in grease or other material both front
I was present at the vehicle with the tester and asked his advice on this. He said there was no flaking on the (visible) lines, just a discolouration. He also said this was typically seen, even on a first MoT for a three year old vehicle! I suggested changing to Cunifer and he said that, despite popular opinion it only gives an extra year or two before it corrodes too! The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #672255 29th Aug 2023 11:36am
Ramblin Man
England 2012 Range Rover Vogue 4.4 V8 Buckingham Blue
FYI : https://www.racinglines.com/cupro-nickel-kunifer-brake-pipe
90% copper 10% Nickel - I’d be surprised if corrosion were an issue on these. TDV8 4.4 2012
Post #672291 29th Aug 2023 9:00pm
pcourtney
CUPRO NICKEL FUEL / BRAKE PIPE HOSE LINE 25FT length £15 quid on ebay - I got 2 rolls Smile
Post #672296 29th Aug 2023 9:24pm
Phoenix
Yet corrosion on copper wiring is a real problem...
Personally I'd replace with coated steel, you can usually get formed repair sections which are coated after bending.
Post #672300 29th Aug 2023 10:25pm
Strider
This is what went on Fatty in 2018, only change to the appearance is it got dirty. Ignore all the snake oil experts its BS.
Post #672301 29th Aug 2023 10:33pm
How the hell can a brake pipe ever not fail straight away on corrosion? WTF?
Post #672303 30th Aug 2023 12:50am
You do have to wonder.....
The MOT manual says....
Rigid brake pipes
Chafing, corrosion or damage to a rigid brake pipe so that its wall thickness is reduced by 1/3 (approximately 0.25 mm for typical hydraulic brake pipe) will fail. As it is sometimes difficult to assess this accurately, if not sure, the Tester will give the benefit of the doubt.
So, an MOT tester can tell just by looking that the pipe is not rusted more than 0.25mm... Shocked
But it's OK if he can't, he just gives the benefit of the doubt.... Shocked Shocked Pete
Post #672314 30th Aug 2023 11:59am
Ennoch
A couple of things. Copper pipe work hardens, particularly at the flares, and vibration can cause failure. Cuprinol is much, much better and the addition of nickel makes a big difference on this to the point it's a non-issue. However, it just isn't as tough from a damage point of view which is partly why manufacturers use steel. It can get ground through more easily, dented more easily and generally gets battered a lot more easily. None are good things in a production environment. Coated steel will last well. The lines on my Impreza are all original and are 20 years old which I find pretty impressive. The biggest issue is that newer cars are suffering line failure earlier than they would have in the past as a result of cheaper steel and lines being tucked up under protective panels more which keeps them wet longer so when the coating does inevitably get breached, they fail more quickly from that point on. I've had replacement lines on cars under 7 years old in the past but generally I think lines last a reasonable amount of time given where they are on a car.
As for the MOT point, it all comes down to judgement from experience. If it's holding fluid and doesn't look like it's about to imminently spring a leak within 3-4 months then it'll usually be passed. An MOT is not a guarantee, but also if they were failing lines for just being a bit corroded then you would have an awful lot of complaints. My experience of working on cars over the last 20 years (not as a professional I hasten to add) is that it's usually pretty easy to tell which lines are done in.
Post #672319 30th Aug 2023 1:56pm
And that was my point… Why not er on the side of caution and fail any brake line that’s compromised? I bet they do in Germany / Switzerland etc etc…
Post #672358 30th Aug 2023 8:18pm
dingg1
Because slight surface corrosion doesn't mean that the line has suffered any diminished ability to contain the fluid at the normal operational pressure.
Most brake pipes will have an amount of corrosion after 5 years, if every bit of corrosion was an immediate fail people would soon get Censored off with renewal of brake pipes that are still very capable of doing what they are designed for..
Post #672363 30th Aug 2023 8:33pm
SamThomas
United Kingdom 2003 Range Rover Vogue Td6 Baltic Blue
As a matter of interest what pressure do brake components operate at ?
Post #672372 30th Aug 2023 10:09pm
An emergency stop puts about 2000psi through the system, normal use under 1000psi......
I still think the MOT should err on the side of safety, not give the benefit of the doubt to a potentially weakened pipe..... Pete
Post #672381 30th Aug 2023 11:49pm
Exactly Peter... 2000PSI or maybe 2500 in an emergency, when you're the size of us lumps Peter!
Whistle Whistle Whistle
Post #672386 31st Aug 2023 12:51am
JayGee
An MOT is only ever a basic set of tests and no guarantee of safety or reliability. You can get an MOT 'pass' (with an advisory) with 4 windsail tyres with 1.6mm of tread but try doing an emergency stop in the wet and a week later when they are below 1.6mm that's potentially a £10k fine and points on your licence. 2012 TDV8 Vogue (L322)
Post #672402 31st Aug 2023 9:03am
Good point well made Jay… Does seam like a heavily outdated scheme these days though ay!
Post #672403 31st Aug 2023 9:16am
Page 2 of 3 <123>
