Home > Maintenance & Mods (L322) > MOT Advisory on Brake pipes |
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 773 |
I've just had my MoT and the front brake lines were an advisory.
29th Aug 2023 10:36am |
Ramblin Man Member Since: 05 Apr 2022 Location: Southsea Posts: 281 |
FYI : https://www.racinglines.com/cupro-nickel-kunifer-brake-pipe
29th Aug 2023 8:00pm |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
Yet corrosion on copper wiring is a real problem... Personally I'd replace with coated steel, you can usually get formed repair sections which are coated after bending. |
29th Aug 2023 9:25pm |
Strider Member Since: 08 Jun 2015 Location: Hertfordshire Posts: 503 |
This is what went on Fatty in 2018, only change to the appearance is it got dirty. Ignore all the snake oil experts its BS.
29th Aug 2023 9:33pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16306 |
How the hell can a brake pipe ever not fail straight away on corrosion? WTF? |
29th Aug 2023 11:50pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8354 |
You do have to wonder.....
30th Aug 2023 10:59am |
Ennoch Member Since: 26 Dec 2015 Location: Scotland Posts: 109 |
A couple of things. Copper pipe work hardens, particularly at the flares, and vibration can cause failure. Cuprinol is much, much better and the addition of nickel makes a big difference on this to the point it's a non-issue. However, it just isn't as tough from a damage point of view which is partly why manufacturers use steel. It can get ground through more easily, dented more easily and generally gets battered a lot more easily. None are good things in a production environment. Coated steel will last well. The lines on my Impreza are all original and are 20 years old which I find pretty impressive. The biggest issue is that newer cars are suffering line failure earlier than they would have in the past as a result of cheaper steel and lines being tucked up under protective panels more which keeps them wet longer so when the coating does inevitably get breached, they fail more quickly from that point on. I've had replacement lines on cars under 7 years old in the past but generally I think lines last a reasonable amount of time given where they are on a car.
30th Aug 2023 12:56pm |
And that was my point… Why not er on the side of caution and fail any brake line that’s compromised? I bet they do in Germany / Switzerland etc etc… |
30th Aug 2023 7:18pm |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1348 |
Because slight surface corrosion doesn't mean that the line has suffered any diminished ability to contain the fluid at the normal operational pressure.
30th Aug 2023 7:33pm |
SamThomas Member Since: 12 Nov 2021 Location: South East Posts: 293 |
As a matter of interest what pressure do brake components operate at ? |
30th Aug 2023 9:09pm |
An emergency stop puts about 2000psi through the system, normal use under 1000psi......
30th Aug 2023 10:49pm |
Exactly Peter... 2000PSI or maybe 2500 in an emergency, when you're the size of us lumps Peter!
30th Aug 2023 11:51pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3283 |
An MOT is only ever a basic set of tests and no guarantee of safety or reliability. You can get an MOT 'pass' (with an advisory) with 4 windsail tyres with 1.6mm of tread but try doing an emergency stop in the wet and a week later when they are below 1.6mm that's potentially a £10k fine and points on your licence. 2012 TDV8 Vogue (L322) |
31st Aug 2023 8:03am |
Good point well made Jay… Does seam like a heavily outdated scheme these days though ay! |
31st Aug 2023 8:16am |
