![]() | Home > In Car Electronics (L322) > Radio again!!! |
William97841 Member Since: 18 Jan 2015 Location: Essex Posts: 141 ![]() ![]() ![]() |
When you say hard reset do you mean disconnect the battery and touch the positive and negative together? |
So tried that last night even put my battery on charge over night touched this morning and reconnected still a black screen and flashing amber light sadly hasn’t done but I shall try more things lol |
Finally fixed the radio but sadly have lost traffic system TA alerts but not worried about that. Lost the iPod connection which was never used as didn’t work right. But now working radio. So basically the blue wire that feeds the radio was giving 0.34 volts so it was broken. Rerouted a new cable and a second fused adapter cable off fuse 49 (dual fused lead) And ran it to the radio. Don’t know how it happened but finally fixed yay. 😀 |
MR GLOVER Member Since: 03 Jan 2015 Location: grimsby Posts: 605 ![]() ![]() ![]() |
well done |
Tall-Paul Member Since: 23 May 2024 Location: manchester Posts: 4 ![]() ![]() ![]() |
Hi Everyone. Opening up this thread rather than making ANOTHER one. I've done my research and investigated the issues, to no avail. I have noticed a bluetooth bypass has already been completed by the previous owner, the plug going into the bluetooth module has 2 corroded pins, this is now unplugged. I have red lights in all the optics. My radio display is on, I can choose different stations but I have no sound. Any ideas? Ive checked the fuses, disconnected the battery for 30 seconds. Silence.
Hi Paul if your getting power and visual display it does sound like an amp problem with no sound. I do know they have gone before |
ok thanks, I'll set about getting a replacement sorted. |
jkmmrs Member Since: 29 Jun 2020 Location: Minnesota Posts: 17 ![]() ![]() ![]() |
On my 2007 FFRR, I'm dealing with the orange flashing light and frozen screen. I ordered a new 1m length of fiber optic cable. The red light goes into and out of the Bluetooth module, but it does not enter the radio module that's next in line - same symptom whether or not I use the MOST loop to bypass the BT module. The cable going into the radio module either has no red light or a very faint red light. So it seems the cable between the BT and radio units is bad. FWIW. |
