Home > In Car Electronics (L322) > Radio again!!!
William97841
When you say hard reset do you mean disconnect the battery and touch the positive and negative together?
Post #666199 8th Jun 2023 6:55pm
DaveAbbott
Hard reset , is the equivalent of switxhing off your computer and re booting it.
So Let the car stand for an hour or so, with No kery in it
Disconnect the battery, negative first , then positive Leave for a couple of hours
Touch the pos & neg leads together and reconnect , negative first.
Re start the motor and turn full lock left and right
That worked for me.
I discovered that the RR infotainment system has a " transport" mode which is what causes it to switch on and off.
The hard reset cured it for me.
Dave
Post #666203 8th Jun 2023 8:26pm
William97841
So tried that last night even put my battery on charge over night touched this morning and reconnected still a black screen and flashing amber light sadly hasn’t done but I shall try more things lol
Post #666300 10th Jun 2023 7:34am
William97841
Solved!!!!!
Finally fixed the radio but sadly have lost traffic system TA alerts but not worried about that. Lost the iPod connection which was never used as didn’t work right. But now working radio. So basically the blue wire that feeds the radio was giving 0.34 volts so it was broken. Rerouted a new cable and a second fused adapter cable off fuse 49 (dual fused lead) And ran it to the radio. Don’t know how it happened but finally fixed yay. 😀
Post #669712 24th Jul 2023 2:16pm
MR GLOVER
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
well done Thumbs Up
Post #669741 24th Jul 2023 8:02pm
Tall-Paul
United Kingdom 2006 Range Rover Vogue SE 4.2 SC V8 Java Black
New frustrated owner
Hi Everyone. Opening up this thread rather than making ANOTHER one. I've done my research and investigated the issues, to no avail. I have noticed a bluetooth bypass has already been completed by the previous owner, the plug going into the bluetooth module has 2 corroded pins, this is now unplugged. I have red lights in all the optics. My radio display is on, I can choose different stations but I have no sound. Any ideas? Ive checked the fuses, disconnected the battery for 30 seconds. Silence.
Thanks, Paul
Post #693182 23rd May 2024 12:54pm
William97841
Hi Paul if your getting power and visual display it does sound like an amp problem with no sound. I do know they have gone before
Post #693194 23rd May 2024 2:49pm
Tall-Paul
ok thanks, I'll set about getting a replacement sorted.
Post #693202 23rd May 2024 3:57pm
jkmmrs
United States 2007 Range Rover HSE 4.4 V8 Tonga Green
On my 2007 FFRR, I'm dealing with the orange flashing light and frozen screen. I ordered a new 1m length of fiber optic cable. The red light goes into and out of the Bluetooth module, but it does not enter the radio module that's next in line - same symptom whether or not I use the MOST loop to bypass the BT module. The cable going into the radio module either has no red light or a very faint red light. So it seems the cable between the BT and radio units is bad. FWIW.
Post #693987 6th Jun 2024 3:10pm
