Home > Technical (L405) > Ride quality -16 SDV8 AB
Page 28 of 35 <123 ... 272829 ... 333435>
MarianaWestminster
I understand what your saying re tyres Jaygee but it can't just be down to tyres on 3 different cars.
I had 3 different sets on one of the RRs, Scorpions, Goodyear Eagles and then General Grabber AT3.
There was barely any difference in how that one drove on each different set.
This l405 is running Scorpion Verdes all round, all less than 2 years old and all with 7mm tread.
Post #668944 12th Jul 2023 10:20am
JayGee
Just went to the start of the thread and you are still on 21" wheels with 45 profile tyres? Maybe worth seeing if you can borrow a set of 20"? I can tell mine get harsher with just 10% higher than stock tyre pressures and I can imagine a lower profile tyre would be harsher still. 2012 TDV8 Vogue (L322)
Post #668949 12th Jul 2023 10:39am
MarianaWestminster
If I knew someone to borrow a set off then I would try them.
I certainly wouldn't buy a set and I say this because I did the opposite on my last l322.
I changed up from 20 inch to 21 inch wheels and there was very little appreciable change.
Probably at the sidewall difference between the 2 tyre sizes is about 3mm.
This has got to be some sort of electrical fault that effects all 3 systems.
Maybe something I'm doing when I get the cars for it to have effected 3.
Post #668959 12th Jul 2023 11:22am
is your tyre pressure set at light or heavy load..
i set mine to heavy and it was distinctively more heavier on the steering.. ... - .- -.
Post #668960 12th Jul 2023 11:26am
MarianaWestminster
Currently set at just below light load on the front 33psi and 33psi on the rear.
I'm only just coping at these pressures.
If I use factory 34F/37R it's untolerable
Post #668961 12th Jul 2023 11:29am
i meant the menu setting.. ... - .- -.
Post #668962 12th Jul 2023 11:52am
MarianaWestminster
Sorry Stan my bad, in the dash it's currently set to light load.
Post #668963 12th Jul 2023 11:55am
JayGee
I suggest dropping the pressures to 25psi all round and going for a very gentle and short drive to see what it feels like. IME sidewall compliance is the main suspension component responsible for dealing with low speed road imperfections. 2012 TDV8 Vogue (L322)
Post #668967 12th Jul 2023 12:33pm
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
Didnt know you could set the load setting on the dash?
Post #668968 12th Jul 2023 12:38pm
you have 2 options doc.. light or heavy , it should flash up when you start your engine.. ... - .- -.
Post #668970 12th Jul 2023 1:43pm
MarianaWestminster
Does a voltage drop to 9 volts when cranking seem okay/normal?
Video:
Post #668971 12th Jul 2023 4:52pm
Mine drops to high elevens and doesn't shoot up to over 15, its a new battery
Maybe yours is on it's way out.... can't see it being your issue but you never know... Thumbs Up Pete
Post #668976 12th Jul 2023 8:27pm
MarianaWestminster
That's interesting then... thanks so much for the comparison Haylands. Thumbs Up
Both the main battery and auxiliary battery are brand new though.
I replaced them as the start stop wasn't working.
Post #668980 12th Jul 2023 8:38pm
MarianaWestminster
Reading a review of the L460 and this is what they have to say about the L405.
Wish I had the car they are referencing:
Post #669224 16th Jul 2023 2:07pm
aljo
United Kingdom 2019 Range Rover Vogue SE 2.0 PHEV Santorini Black
“The L405 rides better than anything this side of a rolls Royce” Big Cry Big Cry
That really is wishful thinking
The trades description act would tear that comment to bits Last night I lay in bed looking up at the stars in the sky and I thought to myself, where,s the f**king ceiling!!
Post #669226 16th Jul 2023 3:40pm
