Home > Technical (L405) > Ride quality -16 SDV8 AB |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3283 |
Just went to the start of the thread and you are still on 21" wheels with 45 profile tyres? Maybe worth seeing if you can borrow a set of 20"? I can tell mine get harsher with just 10% higher than stock tyre pressures and I can imagine a lower profile tyre would be harsher still. 2012 TDV8 Vogue (L322) |
12th Jul 2023 10:39am |
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 687 |
If I knew someone to borrow a set off then I would try them.
12th Jul 2023 11:22am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35436 |
is your tyre pressure set at light or heavy load..
12th Jul 2023 11:26am |
Currently set at just below light load on the front 33psi and 33psi on the rear.
12th Jul 2023 11:29am |
i meant the menu setting.. ... - .- -.
12th Jul 2023 11:52am |
Sorry Stan my bad, in the dash it's currently set to light load. |
12th Jul 2023 11:55am |
I suggest dropping the pressures to 25psi all round and going for a very gentle and short drive to see what it feels like. IME sidewall compliance is the main suspension component responsible for dealing with low speed road imperfections. 2012 TDV8 Vogue (L322) |
12th Jul 2023 12:33pm |
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1433 |
Didnt know you could set the load setting on the dash? |
12th Jul 2023 12:38pm |
you have 2 options doc.. light or heavy , it should flash up when you start your engine.. ... - .- -.
12th Jul 2023 1:43pm |
Does a voltage drop to 9 volts when cranking seem okay/normal?
12th Jul 2023 4:52pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8335 |
Mine drops to high elevens and doesn't shoot up to over 15, its a new battery
12th Jul 2023 8:27pm |
That's interesting then... thanks so much for the comparison Haylands.
12th Jul 2023 8:38pm |
Reading a review of the L460 and this is what they have to say about the L405.
16th Jul 2023 2:07pm |
aljo Member Since: 04 Jul 2018 Location: west sussex Posts: 202 |
“The L405 rides better than anything this side of a rolls Royce”
16th Jul 2023 3:40pm |
