Home > Technical (L405) > Ride quality -16 SDV8 AB |
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1151 |
I can't see Craig but I imagine he is looking worried! overfinch modified |
7th Jul 2023 8:27am |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2537 |
Just to close-out the Defender hard suspension digression, the 2nd dealer confirmed the Gap tool's live value display of 0V to all CVDs while driving so a new chassis module has been ordered. It's taken 7 months to convince a dealer of a problem but at least the issue is now being addressed. |
7th Jul 2023 11:37am |
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 687 |
Hopefully the new module sorts it for the owner Graeme
7th Jul 2023 8:16pm |
Had to do a 2 hour drive today to go to a suit fitting for a friend's wedding.
8th Jul 2023 2:19pm |
aljo Member Since: 04 Jul 2018 Location: west sussex Posts: 202 |
I can remember when I had my problem vehicle with the gap tool that there was a live data output that showed if dampers were hard or soft ! Is that something you have come across ? Last night I lay in bed looking up at the stars in the sky and I thought to myself, where,s the f**king ceiling!!
8th Jul 2023 3:26pm |
Yes that's what I was looking at ref my post above.
8th Jul 2023 4:00pm |
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640 |
I know little on how PWM signals work, so had a google.
9th Jul 2023 10:00am |
I've ordered a second hand chassis control module just to see if it acts any different with that fitted.
9th Jul 2023 10:43am |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1400 |
https://www.rangerovers.net/threads/l405-c...ed.358280/
9th Jul 2023 9:55pm |
I've tried updating both the CHCM and CHCMB to the latest firmware with thanks to Pat and GAP but to no avail.
10th Jul 2023 10:20pm |
You could use a DC clamp meter around the wire that supplies 12V power to the CVD section of the module (brown connector, RH end, large dia wire up 1 row from the bottom) while someone watches the change in current from when stopped to when barely rolling. You would then know the total extra current drawn by the shocks when the bypass valves are meant to be at least partially open as a means of confirming that the shocks are consuming power when they're supposed to be. Alternatively wire-in an ammeter in place of the CVD fuse with wires long enough to allow the ammeter to be seen whle driving. |
11th Jul 2023 4:58am |
Received and connected the second hand CHCM tonight.
11th Jul 2023 8:06pm |
No different this morning, still a stiffer ride first thing with the replacement control module.
12th Jul 2023 6:49am |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3283 |
I've been following this and the other topic on the L322 forum for a while. I'm still not clear exactly what the system is supposed to do as using variable damping seems to be mainly about controlling roll in cornering which is a bit of a fudge compared to more modern systems on cars which have active spring rate and ARB controls. I had a similar setup on my old Audi Allroad - variable dampers and air springs but the system was user selectable between comfort (normal ride height and soft dampers) and sport ( lower ride height and harder dampers) Unintuitively the comfort setting was much better at speed in terms of comfort and the sport setting was more comfortable at low speed around town where the comfort setting was harsh and crashy. Mine had low profile 19" wheels which were I think ultimately why it was crashy and was the main reason in the end why i bought an L322. I have suggested before that low speed comfort is more down to tyres (sidewall compliance) than dampers and a combination of worn dampers and low profile tyres or low compliance ( all terrain) tyres will feel harsh. Mine is 'acceptable' most of the time and is still on original dampers at 160k miles but runs on 255/55 R20 Verde's. My biggest improvement in comfort was when I swopped all 4 tyres out for newer versions of the Verde which were either better designed or the old ones had hardened with age ( 7 years old) 2012 TDV8 Vogue (L322) |
12th Jul 2023 9:29am |
