Home > Technical (L322) > Gearbox learning to behave badly
JayGee
Whenever I do a soft reset on the gearbox (accelerator pedal to the floor - ignition on - hold for 30 seconds - ignition off - release pedal) the gearbox seems to behave in a much more civilised manner but as the days go by the 1-2 upshift gets harsh on low throttle and it feels like it hangs on to revs a bit longer than necessary. It's had a few oil changes and also the latest software update. 2012 TDV8 Vogue (L322)
Post #660100 23rd Mar 2023 9:41am
jagracer
United Kingdom 2011 Range Rover Vogue 4.4 V8 Zermatt Silver
Have you done the relearning cycle to get it back to your driving style?
Post #660121 23rd Mar 2023 12:50pm
DrRob
Why are you doing it out of curiosity? Never heard of that procedure before. Curious.
I’ve had oil changes via a Megaflush at 83K and just now at 120K and never reset any adaptations etc and the gearbox has not changed its feel or behaviour in any way. Don’t fiddle was the advice given by Bodsy on both occasions Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #660122 23rd Mar 2023 12:58pm
JayGee
It's not needed unless you do a hard reset via the ECU. It may not even be a gearbox reset and may just be the accelerator / throttle response reset but the gearbox uses this as an input. 2012 TDV8 Vogue (L322)
Post #660127 23rd Mar 2023 2:02pm
JayGee
. It cures the 1-2 upshift harshness I 've always had. Did it on my Audi which had a ZF box and the procedure was the same. 2012 TDV8 Vogue (L322)
Post #660129 23rd Mar 2023 2:04pm
DrRob
Thumbs Up Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #660135 23rd Mar 2023 3:08pm
garyRR
It's designed to hold onto gears 1 and 2 for longer when cold.
I'd imagine the torque going through the box at higher revs would cause them to be a little more 'jolty' anyway. 2015 Range Rover Autobiography 4.4 SDV8
Post #660154 23rd Mar 2023 6:15pm
JayGee
It's nothing to do with it being cold. 2012 TDV8 Vogue (L322)
Post #660157 23rd Mar 2023 6:46pm
