![]() | Home > Technical (L322) > Gearbox learning to behave badly |
jagracer Member Since: 14 Aug 2021 Location: Norfolk Posts: 113 ![]() ![]() ![]() |
Have you done the relearning cycle to get it back to your driving style? |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4318 ![]() ![]() ![]() |
Why are you doing it out of curiosity? Never heard of that procedure before. Curious.
It's not needed unless you do a hard reset via the ECU. It may not even be a gearbox reset and may just be the accelerator / throttle response reset but the gearbox uses this as an input. 2012 TDV8 Vogue (L322) |
. It cures the 1-2 upshift harshness I 've always had. Did it on my Audi which had a ZF box and the procedure was the same. 2012 TDV8 Vogue (L322) |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 ![]() ![]() |
It's designed to hold onto gears 1 and 2 for longer when cold.
It's nothing to do with it being cold. 2012 TDV8 Vogue (L322) |
