Home > Technical (L322) > Front parking sensor-pull out or push in? |
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 837 |
It should be clipped into the holder that’s bonded to the inside of the bumper, therefore removing requires pressing from the outside inwards, you may need to prise the lugs of the holder open slightly to allow it to be pushed through Jonathan
22nd Mar 2023 3:22pm |
philip1972 Member Since: 16 Jun 2017 Location: Marval 87440 Posts: 511 |
Brilliant, thank you 👍 |
22nd Mar 2023 6:11pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16180 |
As JCW says above, the sensors push inwards BUT... DONT push too hard as the holders are not stuck on very firmly! You need to push the two locking tabs outwards first... |
22nd Mar 2023 11:59pm |
mcspreader Member Since: 28 Jan 2017 Location: cornwall Posts: 56 |
Related to this, my Front Offside sensor appears to have been pushed in at some point. Didn't notice when as I've been suffering from the dreaded switch LED short to battery so the system has been inoperatve for a while. Fixed it by cobbling a LED directly to leads form the module. I'll have a look from inside the wheelarch liner but if the holder on the bumper cover is detached is there any advice for repair? 2011c Vogue SE 4.4 Oil Burner
5th May 2024 4:29pm |
SeldomSeenKid Member Since: 24 Jan 2024 Location: Glasgow Posts: 44 |
Whats the fix for this? I've got a couple that are hanging on. Are they just bonded on? I've had both bumpers off for various jobs, the fronts look easy, but the rear looks like I might need to remove some material from the inner bumper liner. Any ideas? --------------------------------- 2008 L322 Supercharged 2007 Porsche 987 Boxster S 2021 BMW iX3 |
5th May 2024 4:59pm |
