Home > Technical (L322) > Front parking sensor-pull out or push in?
philip1972
France 2006 Range Rover Autobiography 4.2 SC V8 Java Black
Need to replace my front right parking sensor.
I can get access through the wheel arch liner, but it didnt seem to want to come out! I tried removing it from the front of the car and then pushing it backwards towards the engine/
I didnt go mad as I didnt want to break anything!
Any pointers?
Cheers
Post #660038 22nd Mar 2023 2:07pm
JCW
United Kingdom 2010 Range Rover Autobiography TDV8 Santorini Black
It should be clipped into the holder that’s bonded to the inside of the bumper, therefore removing requires pressing from the outside inwards, you may need to prise the lugs of the holder open slightly to allow it to be pushed through Thumbs Up Jonathan
2007 Defender 90 XS Hardtop
Post #660041 22nd Mar 2023 2:22pm
philip1972
Brilliant, thank you 👍
Post #660050 22nd Mar 2023 5:11pm
As JCW says above, the sensors push inwards BUT... DONT push too hard as the holders are not stuck on very firmly! You need to push the two locking tabs outwards first... Thumbs Up
Post #660084 22nd Mar 2023 10:59pm
mcspreader
United Kingdom 2010 Range Rover Vogue SE TDV8 Zermatt Silver
Related to this, my Front Offside sensor appears to have been pushed in at some point. Didn't notice when as I've been suffering from the dreaded switch LED short to battery so the system has been inoperatve for a while. Fixed it by cobbling a LED directly to leads form the module. I'll have a look from inside the wheelarch liner but if the holder on the bumper cover is detached is there any advice for repair? 2011c Vogue SE 4.4 Oil Burner
1991 Hilux 2.4d MkIII. Sadly goone due to space and time.
2008 Skoda Octavia Scout
2000 TVR Tuscan 4.0
Loads of crap. Gone
Post #691968 5th May 2024 3:29pm
SeldomSeenKid
Scotland 2008 Range Rover Supercharged 4.2 SC V8 Stornoway Grey
Whats the fix for this? I've got a couple that are hanging on. Are they just bonded on?
I've had both bumpers off for various jobs, the fronts look easy, but the rear looks like I might need to remove some material from the inner bumper liner.
Any ideas? ---------------------------------
2008 L322 Supercharged
2007 Porsche 987 Boxster S
2021 BMW iX3
Post #691971 5th May 2024 3:59pm
