Home > Maintenance & Mods (L322) > Washer jet upgrade - fan pattern jets
Danb_220_2019
United Kingdom 2012 Range Rover Vogue SE TDV8 Fuji White
The standard two-hole washer jets on the L322 are a PITA to adjust.
My guess was that with the BMW engineering history of the L322, there was a good chance a BMW fan-pattern heated jet would fit, and a bit of eBay picture surfing suggested that E60/61 or E63/64 jets would be a good place to start.
So, since I happen to have an E64 645Ci lying around, I thought I'd try it by swapping the jets from FFRR-E64 and vice-versa.
All fits perfectly without trouble.
My tip is to try and get the jets including the BMW-fitted 90deg fitting - means there's no need to extend the standard L322 washer pipes. Obviously with the car sat in front of me I had access to this anyway.
BMW part numbers for the jet and elbow are 61667054446 and 61668374371
Post #654457 23rd Jan 2023 1:14pm
mjdronfield
Excellent. Would be much better like that..nice one.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #654466 23rd Jan 2023 2:24pm
JayGee
Don't fancy spray patterns need higher pump pressures ? 2012 TDV8 Vogue (L322)
Post #654469 23rd Jan 2023 2:26pm
Danb_220_2019
I can't say I've noticed a problem.
Post #654473 23rd Jan 2023 2:34pm
mjdronfield
Have you got any pics of the difference?
Or a link to what needs to be purchased?
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #654476 23rd Jan 2023 3:07pm
Danb_220_2019
I can't say I have. Car's on charge at present with the battery d/c so I can't run out and take any right now but I'll try and remember to get some tomorrow when I put it back on.
BMW part numbers for the jet and elbow are 61667054446 and 61668374371 - OP edited to include.
Post #654477 23rd Jan 2023 3:19pm
Phoenix
Good bit of lateral thinking there - they know how to charge for them though!
Post #654540 23rd Jan 2023 10:44pm
Danb_220_2019
Indeed - cheaper aftermarket versions available from China on eBay if you can wait a couple of weeks for postage.
Post #654554 24th Jan 2023 9:10am
Danb_220_2019
So it turns out it's really quite difficult to actually get a meaningful photo of washer jets working when there's only one of you and washer fluid is transparent. Add in the wipers doing their job and it's *really* difficult.
I have posted a video on YouTube which I've linked below:
*as a special bonus, you can also see the sacrificial E64 in the background.
Post #654555 24th Jan 2023 9:21am
grayst01
Scotland 2012 Range Rover Vogue 4.4 V8 Java Black
hi Dan, do you know if these would work on later L322 models, ie 2012 4.4TVD8? Cheers, Steven.
2012 Vogue 4.4 TDV8.
Post #654606 24th Jan 2023 2:47pm
Danb_220_2019
Hi Steven
That *is* a 2012 TDV8 Smile
Post #654610 24th Jan 2023 2:56pm
grayst01
Big Cry sorry! I didn’t watch the vid, just jumped on the BMW story and ass u me’d early L322’s… Censored
Thumbs Up Cheers, Steven.
Post #654613 24th Jan 2023 3:01pm
Danb_220_2019
No worries - the only point I was making was because the L322 was originally engineered alongside BMW, it was likely a good place to start (and I've spent enough time under the bonnet of my 645 to suspect they were basically the same jets).
Post #654614 24th Jan 2023 3:03pm
Phoenix
I got a pair of these from a trade-in, they're a bit 'underwhelming' but do cover a wider area with spray. I'm going to try an inline 'booster' pump first, if no good, then I reckon a Ford headlamp washer pump is the correct size to replace the existing screenwash pump.
I'd be a bit miffed if I'd have paid for the washer jets!
Post #655983 7th Feb 2023 9:45pm
Danb_220_2019
That's interesting, I've found the pressure and spray pattern to be absolutely fine with the standard washer pump. I get great coverage and volume of water at all speeds including motorway driving. 2012 (L322) 4.4TDV8 Vogue SE, RSE, Fuji White over Arabica.
Previous V8s: BMW 645Ci, P38 4.6, P38 4.0, Merc CL500
Previous others: Honda x1, Volvo x7, Rover x6, BMW x6, Ford x1, Mercedes x2, Skoda x3, VW x2, Renault x2, Citroen x1, Mazda x3, Nissan x1, Audi x3, Kia x1, Fiat x4, Subaru x3, Austin x2, Triumph x2, Jeep x2, Hyundai x2, Lexus x1, Mitsubishi x1, Saab x2... and some others I've forgotten!
Post #655985 7th Feb 2023 10:02pm
