![]() | Home > Maintenance & Mods (L322) > Washer jet upgrade - fan pattern jets |
I don't have any issues with the standard setup to be honest. The rear is another matter and a spray rather than jets would be a lot better but as the nozzles are integrated into the arm this would be hard to implement. 2012 TDV8 Vogue (L322) |
Yep, the standard ones are 'fine', the fan spray are 'better', I suppose I'm in a position where I can experiment for no, or low cost on a lot of changes. If improving the pressure gets to be too much hassle or costly, then I can easily revert to standard. |
