Home > Maintenance & Mods (L322) > Brake refurb |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2269 |
Evening all having a little issue with the brakes - only on heavy braking it makes a grinding noise and a slight vibration through the wheel New discs and pads still the same so thinking the front calibers need reworking - rears were replaced a couple of years ago and the fronts have been cleaned etc but think after 230k miles and 15years maybe a refurb is in need.
30th Dec 2022 8:16pm |
We use these https://www.bcs-automotive.co.uk/
30th Dec 2022 8:45pm |
Thank you well I never worry about price on stuff like that change my tyres at 4mm Goodyear ultra grip winters and Michelin pilot sport summers
30th Dec 2022 8:59pm |
Came back at just under 500 all in so good value for me |
5th Jan 2023 6:26pm |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3135 |
Evening Sandy,
5th Jan 2023 8:41pm |
They look really good David how long did it take to do ? I do have a small shotblasting kit - problem is once I get started dont know where to stop - just replaced all the control arms again thought it wasn't long ago I did them but it was 5 years and 120k miles and they were all shot
5th Jan 2023 9:19pm |
All good up here thanks You?
5th Jan 2023 9:31pm |
Yes all good Eldest has just bought a 4.4 petrol
5th Jan 2023 9:35pm |
Since the little fella arrived 3 weeks ago I’m using the SC every day and the wife has taken a shine to using it too so i’m on the lookout for a replacement. Can’t work out wether to go 4.4 TDV8 L322 or stretch out to an L405. Someone will likely get a very sorted 4.2SC when the time comes though.
5th Jan 2023 9:57pm |
I'd caution against doing a DIY refurb on brake calipers where you suspect there's an existing issue - the vibration you mentioned even after replacement brake discs & pads...
5th Jan 2023 10:13pm |
