Home > Maintenance & Mods (L322) > Brake refurb
Sandyt
Brake refurb
Evening all having a little issue with the brakes - only on heavy braking it makes a grinding noise and a slight vibration through the wheel New discs and pads still the same so thinking the front calibers need reworking - rears were replaced a couple of years ago and the fronts have been cleaned etc but think after 230k miles and 15years maybe a refurb is in need.
Any suggestions as to where to have it done ?
Post #652113 30th Dec 2022 8:16pm
Phoenix
We use these https://www.bcs-automotive.co.uk/
Not cheap, but it's brakes so why would you cut corners?.
Post #652116 30th Dec 2022 8:45pm
Sandyt
Thank you well I never worry about price on stuff like that change my tyres at 4mm Goodyear ultra grip winters and Michelin pilot sport summers
Post #652119 30th Dec 2022 8:59pm
Sandyt
Came back at just under 500 all in so good value for me Thumbs Up
Post #652668 5th Jan 2023 6:26pm
Andy2986
United Kingdom 2011 Range Rover Vogue TDV8 Barolo Black
I can vouch for BCS.
They have just refurbished all four calipers for my 4.4TDV8 (brembo fronts) and they look stunning.
I havent fitted them yet but as soon as the weather improves i will be swapping them over…..
Can post some pics of the finished calipers if you want to see ?
Andy 2011 4.4 TDV8
2000 4.6 P38
1998 D1 300tdi
Post #652676 5th Jan 2023 6:48pm
dhallworth
Evening Sandy,
I rebuilt the front calipers on my SC as I had a sticking piston in one caliper. Other than the stuck piston being a bit of a sod to remove it was a straight forward job. I’ve had no problems off the brakes since either.
This is the rebuild kit I used:
https://www.ebay.co.uk/itm/263651118044?mk...media=COPY
I then used this paint to paint the calipers after they were rubbed down:
https://www.ebay.co.uk/itm/223471139887?mk...media=COPY
I bought some generic Brembo transfers from eBay too.
Post #652684 5th Jan 2023 8:41pm
Sandyt
They look really good David how long did it take to do ? I do have a small shotblasting kit - problem is once I get started dont know where to stop - just replaced all the control arms again thought it wasn't long ago I did them but it was 5 years and 120k miles and they were all shot
Family all good I hope
Post #652690 5th Jan 2023 9:19pm
dhallworth
All good up here thanks Smile You?
I stripped and rebuilt the calipers, cleaned them up very gently with a wire brush on the grinder in so as not to gouge the aluminium. The hard to reach areas I got a smaller hand held wire brush into. I then cleaned them up with compressed air and white spirit. I did the cleaning after I’d rebuilt them so I didn’t contaminate the innards of the caliper.
The strip, clean and first coat of paint were doing in an evening. I then did a further 2 coats of paint with 24hrs in between as the car was in bits in the workshop at the time and I wasn’t in a hurry to have it back on the road.
Cam-Tech-Craig also suggested using paint protection film over the transfer so that it didn’t lift during pressure washing or cleaning the car too.
Post #652695 5th Jan 2023 9:31pm
Sandyt
Yes all good Eldest has just bought a 4.4 petrol
I might do them myself as I am going to have the transfer box out to replace the bearings and will just use the p38 or one of the others - yours certainly look good and if there is no problem with the function then great
Post #652697 5th Jan 2023 9:35pm
dhallworth
Since the little fella arrived 3 weeks ago I’m using the SC every day and the wife has taken a shine to using it too so i’m on the lookout for a replacement. Can’t work out wether to go 4.4 TDV8 L322 or stretch out to an L405. Someone will likely get a very sorted 4.2SC when the time comes though.
I ended up buying a new transfer box from Duckworths when mine died. I must admit, I didn’t spend long looking at bearings, etc. but wish I had now as they weren’t that expensive.
Post #652702 5th Jan 2023 9:57pm
Phoenix
I'd caution against doing a DIY refurb on brake calipers where you suspect there's an existing issue - the vibration you mentioned even after replacement brake discs & pads...
Reputable places have the experience and the test equipment to determine if there is a problem - and the parts to fix it.
And in the case of BCS, the inspection & test process to make sure everythin g is working as it should (and insurance if it transpires it isn't!).
Post #652708 5th Jan 2023 10:13pm
