![]() | Home > Maintenance & Mods (L322) > Brake refurb |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2269 ![]() ![]() ![]() |
Evening all having a little issue with the brakes - only on heavy braking it makes a grinding noise and a slight vibration through the wheel New discs and pads still the same so thinking the front calibers need reworking - rears were replaced a couple of years ago and the fronts have been cleaned etc but think after 230k miles and 15years maybe a refurb is in need.
We use these https://www.bcs-automotive.co.uk/
Thank you well I never worry about price on stuff like that change my tyres at 4mm Goodyear ultra grip winters and Michelin pilot sport summers
Came back at just under 500 all in so good value for me |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3143 ![]() ![]() ![]() |
Evening Sandy,
They look really good David how long did it take to do ? I do have a small shotblasting kit - problem is once I get started dont know where to stop - just replaced all the control arms again thought it wasn't long ago I did them but it was 5 years and 120k miles and they were all shot
All good up here thanks |
Yes all good Eldest has just bought a 4.4 petrol
Since the little fella arrived 3 weeks ago I’m using the SC every day and the wife has taken a shine to using it too so i’m on the lookout for a replacement. Can’t work out wether to go 4.4 TDV8 L322 or stretch out to an L405. Someone will likely get a very sorted 4.2SC when the time comes though.
I'd caution against doing a DIY refurb on brake calipers where you suspect there's an existing issue - the vibration you mentioned even after replacement brake discs & pads...
