Home > Maintenance & Mods (L405) > Alternative to L405 gear selector
Page 4 of 12 <123 45 ... 101112>
JDGeorgia
United States 2006 Range Rover HSE 4.4 V8 Buckingham Blue
I just spotted our first setback...
I was looking at 2014's near me to go and drive
My '16 Console
'14 RRS Console
Even though the mounting holes look about the same - the RRS has a smaller footprint/presence in the console...
The P-R-N-D-S is incorporated into the Pistol Grip, the bezel around the Pistol Grip is smaller front to back and has a curved edge facing forward...
The Original Owner, Donna, was kind enough to pay $1,510 for Package [088HF] Shadow Walnut Wood Trim - I don't want to mess that up... Maybe I can take the bezel - square off the front edge, or not, and fab an aluminum filler piece that would not look too 'dodgy'. This could put a serious damper on gaslighting the wife into thinking that the pistol grip was there all along. As well as the mass production (that was never going to happen).
Improvise, Adapt, Overcome - seriously... none of you boys have a 3D printer?
If we had a 3D printer - we could just print an entirely new bezel with an extended flat front and paint it with Behr Soft Iron Metallic Satin spray paint - like this incredibly industrious fellow! Rolling with laughter
?si=meo8bP8BMqlmubWO 2006 L322 HSE LUX 4.4NA Jag V8 Buckingham Blue/Ivory - 'Col Reb'
Rolled Yahtzee Aug 2023 222,222Miles
2016 L405 HSE TD6. Santorini Black over Almond. - 'Donna the Diesel'
Only L405 IN THE KNOWN UNIVERSE with an L494 Shift Lever Fitted!
97K at purchase Sept of 2023
Post #676395 25th Oct 2023 9:18am
GraemeS
Australia
Phoenix wrote:
there will be a marking somewhere on the L494 plug to indicate pin 1, but your reasoning makes sense.
Use the empty cavities to confirm in which direction they are numbered.
Post #676401 25th Oct 2023 11:20am
JDGeorgia
@GraemeS That is what I did with the L405 harness - I don't have the same wiring diagram from the L494 so I am kind of guessing - it is a 50/50 proposition. After my morning meetings I will trundle back down to the shop and see if I can find a magnifying glass to look for a mark.
That being said - I think Hot #1 and Ground #10 is the correct sequence
Famous Last words... This is INCORRECT - Pin 10 is Hot and Pin 1 is Ground/Earth 2006 L322 HSE LUX 4.4NA Jag V8 Buckingham Blue/Ivory - 'Col Reb'
Post #676409 25th Oct 2023 1:37pm
JDGeorgia
So let me know when y'all get sick of these random posts... Or if it is too many pics or if I am breaking any rules.
Further Opportunities to add to the Highlight Reel...
The opportunities are mounting at a rapid pace I am afraid...
The L494 Shift is screwed DOWN into a 'frame' - because of the torque of moving the lever back and forth, no doubt. The internal spring has a real 'shift' feel to it.
Our L405 has a tiny rotational force applied getting from P to D... and it is bolted to the top of the console from underneath...
The top of the L494 mounting frame on the lever is 2mm difference as well - this would make it tilt back if screwed from underneath...
More detail on the L494 Male Connector:
There are marks on the BACK of the connector, I was looking on the front.
1 is Black/Ground and 10 is Hot - so I will have flip my diagram back.
The face of the connector has what appears to be MFG markings - Logo I cant make out, PBT-GF30, random #2
On the bottom is probably the MFG Lot number - 1452187-1 / 1428913
Some Pics of the internals (as far as I wanted to go) into the L494 Lever
The black thing in a white frame appears to be a magnet. Under Power - this may be what opens the 'gate' to the Sport side.
That is probably enough out of me today...
if anyone has a better pic of a disassembled L405 console - I would love to see the pics! 2006 L322 HSE LUX 4.4NA Jag V8 Buckingham Blue/Ivory - 'Col Reb'
Post #676445 25th Oct 2023 6:59pm
Phoenix
There was a UK fleabay seller offering the L494 shift in the frame, I was wondering if it'd be needed... Are there any fixing points under the L405 selector that look like they could be used to secure the frame?
Personally I think I'd want to secure the L494 shifter to something a bit more substantial than the trim frame if the required force is noticable, bearing in mind that it'll be amplified on the fasteners due to the relative length of the lever from the pivot point x the inbuilt resistance and centre-return characteristic.
Maybe there's scope for something like a bag full of epoxy beneath the shifter that is squashed down when the shifter is fitted and left to set so that it forms a removable 'cup' to restrain the shifter when in situ?
PBT-GF30 is the mandated details of the material the connector is made from.
The other numbers are very useful!
https://www.te.com/usa-en/product-1452187-1.html
Post #676447 25th Oct 2023 7:14pm
Abacus405
United Kingdom 2017 Range Rover Vogue SE TDV6 Carpathian Grey
Far from sick of your posts. Keep them up and keep going! 2017 (67) Vogue SE Corinthian Grey
Post #676449 25th Oct 2023 8:05pm
JDGeorgia
So Sensei...
You decoded the (Fe)Male Connector (Housing for female terminals) - it is a very confusing world...
When I get the same pigtail for the L405 - can you take the female connector size that needs and tell me the pins that I need for the SCAB(scavenged L405 connector)? I imagine that they are the same...
As far as the frame - I have not been into my L405 - I have been scouting out YouTube videos generally of "L405 Center console removal". So far there is nothing that has rocked my socks like the Powerful UK Vid of the L494 Console removal... I am not sure if the frame would have a place to live under the console or not... it would certainly change the mounting height and position. It may be better to reinforce the upper console to withstand the torque. At least that way the mounting holes can be used.
This may be turning into a Proof of Concept exercise. If I screw the shifter upward into the top of the console - it will last a couple of days worth of shifting easily...
We will be answering - Will the electronics work? Can the shifters be swapped and the truck still go forward and back?
I think we may have already proven that even if we had a ready-made pigtail, and even if we went further and had a 3D Printed bezel... This project may be beyond the skills of your average shade tree mechanic.
I won't know for sure until I am into the console what additional fab or frame or whatnot would be required for a long term/permanent solution. If we had all kinds of toys, we would laser scan the open console and design a 3D printed lower frame. Scan the opening around the Lever and print an extended bezel, and make up a pigtail - Bring Your Own Lever - plug and play...
For the install of the Merryway head unit, all I needed was about 2 sizes of Torx drivers, a tiny philip's head, some side cutters and a Dremel. The dash looked a bomb went off - but it truly was plug and play. 2006 L322 HSE LUX 4.4NA Jag V8 Buckingham Blue/Ivory - 'Col Reb'
Post #676451 25th Oct 2023 8:18pm
Phoenix
The receptacles will need to be housing specific but if you want to use the part from the L405 selector, then standard --- pins will fit - as a test, you could mount them with quick set epoxy but you'll need to have the plug in the housing so that the pins can be held by the female contacts in the correct position, I'd use a very small amount of adhesive put in place with a cocktail stick or similar. Once the initial position is set, then take the plug out and be a bit more free with the epoxy, before you do all that, slide some short lengths of heatshrink tubing over the wires so you can insulate the remaining bits of bare metal.
TBH, as long as the vehicle isn't a very early or later than 16MY (and the parts also are of that vintage) then I can't see why it wouldn't work - maybe 'breadboard' the wiring to confirm functionality before getting into mounting of hardware? you can get --- pigtails pre-assembled on wire (0.5mm will be plenty big enough) which would be ideal for testing.
Will be updated with correct contact family
Post #676452 25th Oct 2023 8:36pm
JDGeorgia
Phoenix, do you have a link for these connectors - and even better if I can get them with different colored wire already in them!
I may have a kit in the shop with automotive Pins - now that I think about it.
I have 16 and 18 gauge wire - 10 colors 5' long as well as heat shrink headed this way.
The mounting and trim issues have put a bit of a damper on my spirit - but that could change when I crack the console on my truck. 2006 L322 HSE LUX 4.4NA Jag V8 Buckingham Blue/Ivory - 'Col Reb'
Post #676454 25th Oct 2023 8:47pm
Phoenix
Sorry mate - was just looking for a supplier and realised it MQS (corrected above) they're TE manufactured and widely available - usually only in single colours. The pins are here https://www.automotiveconnectors.com/te-am...908-1.html M-B part number for an assembled repair line in 0.75mm is A 000 540 46 05 - no idea what they'd cost though!
Somethings not right with those pins - I need to check it out at work in the morning.
Post #676460 25th Oct 2023 9:20pm
JDGeorgia
REVISED PIGTAIL PIN TO PIN R2 10/26/2023
10/26/23 - trying to delete the bad info I originally posted in case someone stumbles across this one day...
I heard back from a fellow called Mike at Auto-Click auto-click.co.uk. I have been misgendering connectors most of my life - kind of surprised I have not been cancelled...
You pay attention to the naughty bits not the housing (seems like sound advice for gendering).
The 'Scab' connector has the Pins as its naughty bits - so therefore it is MALE. The connector in the L405 has the receptacle slot and is therefore the Female. The Female connector slides into the male connector. Maybe this was well known by everyone else, and y'all were too kind to call me a moron.
This will be wired as a pigtail to the FEMALE that fits the bottom of the L494 Connector
For those scoring at home... I physically have the 10 pin L494 FEMALE connector as well as the pistol grip shifter. I do NOT have an L494 wiring diagram. Thanks to Phoenix - I have an L405 Wiring Diagram... but did not crack the console on my truck. I currently do not have any L405 electrical components in hand. I have an L405 gear selector 'FEMALE' pigtail and 'MALE Scab' connector headed this way. Take this with a grain of salt, but I *think* this should be correct. Pretty sure I said that a couple of days ago as well...
L405 MALE Plug is first:
1 - Brown/Red to L494 - 10
2 - Green/Orange to L494 - 9
3 - Open
4 - Open
5 - Twist Green/Orange to L494 - 2
6 - Twist Grey/Blue to L494 - 3
7 - Open
8 - Open
9 - Open
10 - White/Brown to L494 - 8
11 - Green to L494 - 6
12 - Black to L494 - 1
More housekeeping... I have Pins that should work in the L405 Male Scab. They are a good fit for the L494 Female connector - I imagine the L405 is the same size. I like the idea of inserting the connector 3/4 of the way into the scab to keep spacing. I will use AC Glue, a tooth pick, and activator for the initial set - then hit them with some epoxy once I remove the 'male' connector.
I also confirmed that Pins 2&3 are a twisted pair on the L494 pigtail.
@Phoenix - if nothing else... I am coachable... 2006 L322 HSE LUX 4.4NA Jag V8 Buckingham Blue/Ivory - 'Col Reb'
Post #676464 25th Oct 2023 11:24pm
GraemeS
Australia
I wouldn't glue the pins into the housing, instead fit heatshrink to cover each pin. Electrical tape wrapped around the whole lot with the wires for the inserted pins folded back onto the housing could be used to ensure that the pins don't work their way out, not that they would unless there is tension on the wires.
If you solder the wires to the pins then the wires will need to be restrained to prevent breakage at the end of the solder migration if there's any movement in the wires, so best to fold them over and tape in place.
Post #676469 26th Oct 2023 2:16am
Phoenix
Mystery solved - there are three variants of the MQS contacts, the ones for this application are 0.63 x 0.63mm - if the ones you have fit, then they'll be fine. I'd still recommend bonding the pins (ideally crimped, not soldered) in place as signal lines, especially PT CAN are not at all tolerant of disruption caused by contact movement or fretting, better to mechanically fix the contacts in the housing and let the electrical contacts be just that - electrical contacts, not mechanical restraints, that is the job of the contact housing ('connector'). Ideally we need to get sight of the L405 harness plug to get any markings from it, that will help in identifying a mating connector.
Post #676472 26th Oct 2023 8:15am
aljo
United Kingdom 2019 Range Rover Vogue SE 2.0 PHEV Santorini Black
Would the L494 wiring diagrams be availible on topix ? if so I dont mind paying to download the diagrams you need to help you out
Cant seem to find any relevant transmission diagrams with the tried and trusted google search Whistle Last night I lay in bed looking up at the stars in the sky and I thought to myself, where,s the f**king ceiling!!
Post #676513 26th Oct 2023 8:10pm
Phoenix
JDGeorgia wrote:
What's that bit of harness in the above photo? is that for the L405 gearshift? if so, are there any markings on it?
Post #676518 26th Oct 2023 8:38pm
