Home > Maintenance & Mods (L405) > Alternative to L405 gear selector |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2513 |
Use the empty cavities to confirm in which direction they are numbered. |
25th Oct 2023 10:20am |
JDGeorgia Member Since: 11 Oct 2023 Location: Atlanta GA Posts: 158 |
25th Oct 2023 12:37pm |
So let me know when y'all get sick of these random posts... Or if it is too many pics or if I am breaking any rules.
25th Oct 2023 5:59pm |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
There was a UK fleabay seller offering the L494 shift in the frame, I was wondering if it'd be needed... Are there any fixing points under the L405 selector that look like they could be used to secure the frame?
25th Oct 2023 6:14pm |
Abacus405 Member Since: 01 Feb 2022 Location: West yorkshire Posts: 98 |
Far from sick of your posts. Keep them up and keep going! 2017 (67) Vogue SE Corinthian Grey |
25th Oct 2023 7:05pm |
So Sensei...
25th Oct 2023 7:18pm |
The receptacles will need to be housing specific but if you want to use the part from the L405 selector, then standard --- pins will fit - as a test, you could mount them with quick set epoxy but you'll need to have the plug in the housing so that the pins can be held by the female contacts in the correct position, I'd use a very small amount of adhesive put in place with a cocktail stick or similar. Once the initial position is set, then take the plug out and be a bit more free with the epoxy, before you do all that, slide some short lengths of heatshrink tubing over the wires so you can insulate the remaining bits of bare metal.
25th Oct 2023 7:36pm |
Phoenix, do you have a link for these connectors - and even better if I can get them with different colored wire already in them!
25th Oct 2023 7:47pm |
25th Oct 2023 8:20pm |
REVISED PIGTAIL PIN TO PIN R2 10/26/2023
25th Oct 2023 10:24pm |
I wouldn't glue the pins into the housing, instead fit heatshrink to cover each pin. Electrical tape wrapped around the whole lot with the wires for the inserted pins folded back onto the housing could be used to ensure that the pins don't work their way out, not that they would unless there is tension on the wires.
26th Oct 2023 1:16am |
Mystery solved - there are three variants of the MQS contacts, the ones for this application are 0.63 x 0.63mm - if the ones you have fit, then they'll be fine. I'd still recommend bonding the pins (ideally crimped, not soldered) in place as signal lines, especially PT CAN are not at all tolerant of disruption caused by contact movement or fretting, better to mechanically fix the contacts in the housing and let the electrical contacts be just that - electrical contacts, not mechanical restraints, that is the job of the contact housing ('connector'). Ideally we need to get sight of the L405 harness plug to get any markings from it, that will help in identifying a mating connector. |
26th Oct 2023 7:15am |
aljo Member Since: 04 Jul 2018 Location: west sussex Posts: 202 |
Would the L494 wiring diagrams be availible on topix ? if so I dont mind paying to download the diagrams you need to help you out
26th Oct 2023 7:10pm |
What's that bit of harness in the above photo? is that for the L405 gearshift? if so, are there any markings on it? |
26th Oct 2023 7:38pm |
