![]() | Home > Maintenance & Mods (L405) > Alternative to L405 gear selector |
Bora20 Member Since: 03 Mar 2021 Location: Kamloops, BC Posts: 245 ![]() ![]() ![]() |
https://landrover.lakeridgeparts.com/a/Lan...22565.html
aljo Member Since: 04 Jul 2018 Location: west sussex Posts: 202 ![]() ![]() ![]() |
Does the American market use the shift lever on the L405 ?
Just had a quick look through the complete ccf files with my gap g3 iid Bt tool and can’t see anything that would need to be changed in order for a stick shift to be enabled ? So hopefully would be a straight plug and play Last night I lay in bed looking up at the stars in the sky and I thought to myself, where,s the f**king ceiling!!
Salsbury Member Since: 19 Jun 2022 Location: Alberta Posts: 109 ![]() ![]() ![]() |
Hello from Canadia! Nope they all have the washing machine dials to the best of my knowledge. |
Hey Bora - this J-turn showmanship scores rather high on the spectacle-o-meter, what with it taking a tumble more than a gymnast at the Olympics. But in terms of actual effectiveness? It's down there with a chocolate fireman, I'm afraid.
JDGeorgia Member Since: 11 Oct 2023 Location: Atlanta GA Posts: 160 ![]() ![]() ![]() |
The L405 uses a 12 pin connector but only 7 are used. Electrically it wouldn't/shouldn't be an issue, the biggest problem I can see is that the L494 mounting frame is angled, meaning that the trim filler wouldn't sit flat in the L405 mounting frame. Next time we have a L494 trade-in I'll do a bit of side-by-side investigation, I've a feeling the CAN address structure means that if it can be electrically & mechanically fitted, the donor would at least need to be from the same MY for it to be recognised on the Powertrain CAN. |
I would LOVE to do this...
OK Boys... this could be happening, it may take a year to gather all the bits/pieces and find a weekend when the wife is out of town and not wondering why I am taking apart a perfectly good truck... That being said - this is out of a 2014 L494 and mine is a 2016 L405... If Phoenix is right - that could be an issue. If anyone has a lead on an old CHEAP wiring loom for the L494 shifter - I could use that as the male side of a pigtail (short wire loom that converts one plug to another) The female side of the pigtail... is tougher. I may have to get another spinny knob and cannibalize the connector - This is when I wish I had a 3D printer... If any of the experts on here know of where to get these connectors... Send leads my way! ![]()
Rolled Yahtzee Aug 2023 222,222Miles 2016 L405 HSE TD6. Santorini Black over Almond. - 'Donna the Diesel' Only L405 IN THE KNOWN UNIVERSE with an L494 Shift Lever Fitted! 97K at purchase Sept of 2023 |
This is the place I use https://www.auto-click.co.uk/ there's probably a USian version - send them a photo of the connectors and they'll usually be able to work from that.
Thanks Phoenix!
One step closer...
At least some if not all of the wiring colours appear to be the same - I don't have any wiring diagrams for the L494 so I can't give you a pin-to-pin conversion table.
You'll have to check the measurements, I reckon this could be made to fit....
