Home > Technical (L405) > Passenger door wont unlock |
RRVSE-2 Member Since: 06 Jun 2015 Location: Kent Posts: 41 |
Had this on my 2014, but on the drivers door. They replaced the latch as apparently it is a solenoid switch in the mechanism fails, quite common they said. Keith
17th Sep 2018 8:13am |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7923 |
Me too -mine was the drivers door
17th Sep 2018 8:47am |
AndyS Member Since: 27 Feb 2016 Location: Lymington, Hampshire Posts: 402 |
Do we know if the new module is an updated version or is the same old dodgy original one that's likely to fail again in the future ? |
17th Sep 2018 10:43am |
pld118 Member Since: 25 Mar 2013 Location: Bairns Posts: 4218 |
Ours went in for "interim service" at the MD today (had a "major service") last time.
27th Feb 2020 9:37pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16281 |
I do loads of these on 405's! Always the tiny electric motor in the bottom that fails... |
27th Feb 2020 10:00pm |
It's covered under the LR Extended Warranty.
28th Feb 2020 5:03pm |
This issue has recurred.
9th Jan 2022 3:48pm |
zoso Member Since: 20 Aug 2014 Location: Ayrshire Posts: 79 |
I had this issue when I had my 2013 L405. I replaced the solenoid and that appeared to fix it for a couple of weeks but the fault recurred so obviously not that. I then read online somewhere that it can be fixed by clearing the fault code then disconnecting the battery (for 10 mins) and resetting.. That's what I did eventually and it never happened again 2017 4.4 TDV8 Autobiography
17th Jan 2022 10:48pm |
Did they definitely change yours Ryan? Or did they lube it first? |
17th Jan 2022 11:55pm |
Bora20 Member Since: 03 Mar 2021 Location: Kamloops, BC Posts: 236 |
My right rear passenger door won’t open from the inside at times. Soft close door. Cycling the child lock switch on the drivers door will allow it to open. Doesn’t effect the left rear door. I assume I need a new mechanism. Can anyone confirm? Dan. 🇨🇦 2013 L405 5.0 SCV8 |
18th Jan 2022 3:00pm |
Yes it sounds like it needs replacing sir… However, don’t leave it because if it permanently fails in the deadlocked position, it’ll mean cutting open the door to open it!!! So, do it sooner rather than later 👍 |
18th Jan 2022 5:38pm |
Thanks Craig.
18th Jan 2022 5:52pm |
The latch is at fault… The second picture is of the soft close motor assembly…
18th Jan 2022 9:20pm |
Thank you sir! Now the search to not pay $400 CAD for it... Dan. 🇨🇦 2013 L405 5.0 SCV8 |
18th Jan 2022 9:32pm |
