Home > Maintenance & Mods (L405) > Grille swap question
Page 1 of 3 123>
Salsbury
Canada 2014 Range Rover 5.0 SC V8 Barolo Black
Hello All.
I just installed a 2018 "style" grille on my 2014 405.
The new grille is from China and looks and fits fine.
Question: On the inside of the original grille there is a metal brace in the middle (refer to photo).
1. I couldn't work out how to remove it and place it on the new grille - does anyone have experience with these weird fasteners?
2. I installed the new grille without the metal brace given it doesn't look like it performs an important function - any contrary views?
Many thanks.
Post #648379 17th Nov 2022 9:40pm
Phoenix
Those 'weird fasteners' are split rivets, used on plastic components as the compression is lower than traditional pop rivets and therefore won't crack or split the plastic components, quite common in automotive use, difficult to find from engineering suppliers.
I'd say the metal bracket is a stiffening brace to prevent vibration or chatter under ram air load.
Post #648380 17th Nov 2022 9:49pm
Salsbury
Thanks for the explanation.
So I could drill them out and reinstall using normal rivets?
Post #648381 17th Nov 2022 10:03pm
Phoenix
Be careful with the rivets, they're split and have a thinner reduced section on the shank so they don't put excessive load on the plastic, you could put some washers under the heads so as to spread the load if you can't get the right ones.
Post #648382 17th Nov 2022 10:07pm
Salsbury
FAB
Post #648384 17th Nov 2022 10:11pm
Gremlin500
I installed mine without, left it on the original grille, 9 months later no issues at all, no noise vibration etc.
So I think its fine to leave it on the old grille, but keep the OEM grille so the next owner can choose to go OEM if he wishes.
Some dealers/traders will try to haggle you down over non-OEM parts and having to “restore” back to the original spec. Thumbs Up “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #648385 17th Nov 2022 10:15pm
SVAuto_Man
United Kingdom 2019 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
I did wonder what the bracket does, have one on mine and dent understand its function. and being about 3mm thick steel, bit over kill? 2019 L405 SV Autobiography
Post #648408 18th Nov 2022 9:10am
Harmonic dampening device… Stops creaking/rattling… Same devices found all over Range Rovers… Exhaust, bumpers, ARB’s… Loads of them…
Post #648422 18th Nov 2022 10:17am
SVAuto_Man
Makes sense. Just thought 3mm thick was a bit over kill lol 2019 L405 SV Autobiography
Post #648423 18th Nov 2022 10:20am
It’s the weight that is critical… The harmonic dampers on a D4 rear bumper would brake your foot if you dropped it!
Post #648434 18th Nov 2022 12:10pm
SVAuto_Man
Yep understood. Just painted mine a little as it was looking off. Wondered why it had felt pads fitted that touched nothing lol 2019 L405 SV Autobiography
Post #648436 18th Nov 2022 12:13pm
James W
Saudi Arabia 2017 Range Rover Autobiography SDV8 Siberian Silver
Re: Grille swap question
Salsbury wrote:
Hello All.
Many thanks.
Any chance of a pic of your new grille? I'm itching to upgrade mine as I don't like the full silver look FFRR SDV8 Autobiography
Post #648438 18th Nov 2022 12:20pm
Gremlin500
@ James W:
This is the MY 2018 one I got from AliExpress, fitted easily in about 20 mins to my MY2017 Thumbs Up “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #648446 18th Nov 2022 1:42pm
the range rover badge isnt strait [horizontal]
mine is Mr. Green
Post #648447 18th Nov 2022 1:55pm
RutlandBoy
United Kingdom 2015 Range Rover Vogue SE SDV8 Santorini Black
Don't know if it helps or is too late.
But don't 'drill them out
Use a small screwdriver to push the 'inner round part' up and then with draw them from the other side.
You can then re-use them to fit to the other part.
Apologies if you know this already !!!
Good Luck ! L405 4.4 V8 Vogue SE Santorini Black
RRS L390 4.2 S/C Stornoway Grey
Classic Range Rover Overfinch 5.7 - their first prototype - under restoration
Late Range Rover P38
Range Rover 3.9 Classic Softdash
Range Rover Classic Overfinch 5.7 - Sadly gone
Disco 3 - Gone
Disco 2 - Gone
TD5 - Gone
Post #648448 18th Nov 2022 1:56pm
Page 1 of 3 123>
