Home > Maintenance & Mods (L405) > Grille swap question |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
Those 'weird fasteners' are split rivets, used on plastic components as the compression is lower than traditional pop rivets and therefore won't crack or split the plastic components, quite common in automotive use, difficult to find from engineering suppliers.
17th Nov 2022 9:49pm |
Salsbury Member Since: 19 Jun 2022 Location: Alberta Posts: 102 |
Thanks for the explanation.
17th Nov 2022 10:03pm |
Be careful with the rivets, they're split and have a thinner reduced section on the shank so they don't put excessive load on the plastic, you could put some washers under the heads so as to spread the load if you can't get the right ones. |
17th Nov 2022 10:07pm |
FAB |
17th Nov 2022 10:11pm |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1486 |
I installed mine without, left it on the original grille, 9 months later no issues at all, no noise vibration etc.
17th Nov 2022 10:15pm |
SVAuto_Man Member Since: 16 Aug 2022 Location: Coventry, UK Posts: 110 |
I did wonder what the bracket does, have one on mine and dent understand its function. and being about 3mm thick steel, bit over kill? 2019 L405 SV Autobiography |
18th Nov 2022 9:10am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16294 |
Harmonic dampening device… Stops creaking/rattling… Same devices found all over Range Rovers… Exhaust, bumpers, ARB’s… Loads of them… |
18th Nov 2022 10:17am |
Makes sense. Just thought 3mm thick was a bit over kill lol 2019 L405 SV Autobiography |
18th Nov 2022 10:20am |
It’s the weight that is critical… The harmonic dampers on a D4 rear bumper would brake your foot if you dropped it! |
18th Nov 2022 12:10pm |
Yep understood. Just painted mine a little as it was looking off. Wondered why it had felt pads fitted that touched nothing lol 2019 L405 SV Autobiography |
18th Nov 2022 12:13pm |
James W Member Since: 29 Nov 2009 Location: Riyadh Posts: 292 |
Any chance of a pic of your new grille? I'm itching to upgrade mine as I don't like the full silver look FFRR SDV8 Autobiography |
18th Nov 2022 12:20pm |
@ James W:
18th Nov 2022 1:42pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35343 |
the range rover badge isnt strait [horizontal]
18th Nov 2022 1:55pm |
RutlandBoy Member Since: 20 Mar 2022 Location: East Northants Posts: 31 |
Don't know if it helps or is too late.
18th Nov 2022 1:56pm |
