![]() | Home > Maintenance & Mods (L405) > Grille swap question |
Those 'weird fasteners' are split rivets, used on plastic components as the compression is lower than traditional pop rivets and therefore won't crack or split the plastic components, quite common in automotive use, difficult to find from engineering suppliers.
Salsbury Member Since: 19 Jun 2022 Location: Alberta Posts: 109 ![]() ![]() ![]() |
Thanks for the explanation.
Be careful with the rivets, they're split and have a thinner reduced section on the shank so they don't put excessive load on the plastic, you could put some washers under the heads so as to spread the load if you can't get the right ones. |
FAB |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1692 ![]() ![]() ![]() |
I installed mine without, left it on the original grille, 9 months later no issues at all, no noise vibration etc.
SVAuto_Man Member Since: 16 Aug 2022 Location: Coventry, UK Posts: 110 ![]() ![]() ![]() |
I did wonder what the bracket does, have one on mine and dent understand its function. and being about 3mm thick steel, bit over kill? 2019 L405 SV Autobiography |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16341 ![]() ![]() ![]() |
Harmonic dampening device… Stops creaking/rattling… Same devices found all over Range Rovers… Exhaust, bumpers, ARB’s… Loads of them… |
Makes sense. Just thought 3mm thick was a bit over kill lol 2019 L405 SV Autobiography |
It’s the weight that is critical… The harmonic dampers on a D4 rear bumper would brake your foot if you dropped it! |
Yep understood. Just painted mine a little as it was looking off. Wondered why it had felt pads fitted that touched nothing lol 2019 L405 SV Autobiography |
James W Member Since: 29 Nov 2009 Location: Riyadh Posts: 295 ![]() ![]() ![]() |
Any chance of a pic of your new grille? I'm itching to upgrade mine as I don't like the full silver look FFRR SDV8 Autobiography |
@ James W:
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35671 ![]() ![]() |
the range rover badge isnt strait [horizontal]
RutlandBoy Member Since: 20 Mar 2022 Location: East Northants Posts: 31 ![]() ![]() ![]() |
Don't know if it helps or is too late.
