![]() | Home > Technical (L405) > Knocking noise from front |
adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 796 ![]() ![]() ![]() |
&list=LL&index=17&t=90s |
Wogger Member Since: 12 Jun 2016 Location: Nottinghamshire Posts: 407 ![]() ![]() ![]() |
Cheers mate
Bora20 Member Since: 03 Mar 2021 Location: Kamloops, BC Posts: 239 ![]() ![]() ![]() |
I have sway bar bushings and hardware on order. I already replaced the sway bar end links and both front lower control arms. Same symptoms as you, although everything was worn. Dan. 🇨🇦 2013 L405 5.0 SCV8 |
I’m tempted to let the garage replace the dampers, as it’s all being done under warranty, hopefully then by the time it’s all sorted, I might have mostly new suspension up front |
Wouldn’t be “tempted”, would maximise all you can get out of the warranty 👍 |
Just as an update, all suspect parts replaced, knocking gone, car drives perfect, thanks for the advice chaps |
Which parts specifically?
horse86 Member Since: 09 Dec 2014 Location: PA Posts: 863 ![]() ![]() ![]() |
x2 on which parts? I did all 4 lower control arms and sway arm bushing and end links and still get clunk from front end 2014 FF Autobiography 5.0 SC
Me too.
Mine has to be suspension related at I get it when turning to ho over driveway apron on a 45*. I also sometimes get just turning the steering wheel after backing out over the driveway apron when putting it into drive it will clunk starting forward/turning the steering wheel back 2014 FF Autobiography 5.0 SC
