Home > Technical (L405) > Knocking noise from front
Wogger
England 2010 Range Rover Vogue TDV8 Orkney Grey
I have a knocking noise coming from the front of my 2013, 405.
It’s been to the garage a couple of times, but not sorted.
I’m no mechanic, so bear with me, they’ve changed the front lower arms? No joy !!
They now think it could be the dampers, I’m not so sure.
The noise is worse at low speeds, as you go faster, it’s less pronounced.
I’ve had a trawl on the tinterweb, and found that it might be another couple of arms with rubber bushes on the ends??
Please excuse the poor description, any suggestions please. Rolling Eyes
Cheers
Post #645665 15th Oct 2022 8:10am
adara
Romania 2019 Range Rover Vogue 2.0 PHEV Santorini Black
&list=LL&index=17&t=90s
Post #645669 15th Oct 2022 9:15am
Wogger
Cheers mate
I’m sure they’re the culprit
Post #645698 15th Oct 2022 1:03pm
Bora20
Canada 2013 Range Rover 5.0 SC V8 Santorini Black
I have sway bar bushings and hardware on order. I already replaced the sway bar end links and both front lower control arms. Same symptoms as you, although everything was worn. Dan. 🇨🇦 2013 L405 5.0 SCV8
Post #645718 15th Oct 2022 5:07pm
Wogger
I’m tempted to let the garage replace the dampers, as it’s all being done under warranty, hopefully then by the time it’s all sorted, I might have mostly new suspension up front Thumbs Up
Post #645751 15th Oct 2022 11:10pm
pld118
Wouldn’t be “tempted”, would maximise all you can get out of the warranty 👍
Post #645756 16th Oct 2022 9:08am
Wogger
Post #645784 16th Oct 2022 3:05pm
Wogger
Just as an update, all suspect parts replaced, knocking gone, car drives perfect, thanks for the advice chaps Thumbs Up
Post #646553 25th Oct 2022 9:55pm
Bora20
Which parts specifically?
I am replacing the front and rear swaybar bushings tonight if I have enough time. Dan. 🇨🇦 2013 L405 5.0 SCV8
Post #646555 25th Oct 2022 10:02pm
horse86
United States 2014 Range Rover Autobiography 5.0 SC V8 Causeway Grey
x2 on which parts? I did all 4 lower control arms and sway arm bushing and end links and still get clunk from front end 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #646992 31st Oct 2022 7:13pm
Bora20
Me too.
I am down to upper control arms, air struts, and the transfer case/driveline.
I am pretty certain it is the transfer case/driveline. I have completed a transfer case software update, double flush and recalibrated once. I need to recalibrate again. It is a significant clunk at wide-open throttle and a hard downshift. It will also make the clunk when in S1. I think it is the transfer case plates locking the electronic differential.
I have no one to compare against though. Dan. 🇨🇦 2013 L405 5.0 SCV8
Post #646994 31st Oct 2022 7:20pm
horse86
Mine has to be suspension related at I get it when turning to ho over driveway apron on a 45*. I also sometimes get just turning the steering wheel after backing out over the driveway apron when putting it into drive it will clunk starting forward/turning the steering wheel back 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #647002 31st Oct 2022 8:51pm
