Home > Technical (L405) > Knocking noise from front |
adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 766 |
&list=LL&index=17&t=90s |
15th Oct 2022 8:15am |
Wogger Member Since: 12 Jun 2016 Location: Nottinghamshire Posts: 407 |
Cheers mate
15th Oct 2022 12:03pm |
Bora20 Member Since: 03 Mar 2021 Location: Kamloops, BC Posts: 234 |
I have sway bar bushings and hardware on order. I already replaced the sway bar end links and both front lower control arms. Same symptoms as you, although everything was worn. Dan. 🇨🇦 2013 L405 5.0 SCV8 |
15th Oct 2022 4:07pm |
I’m tempted to let the garage replace the dampers, as it’s all being done under warranty, hopefully then by the time it’s all sorted, I might have mostly new suspension up front |
15th Oct 2022 10:10pm |
Wouldn’t be “tempted”, would maximise all you can get out of the warranty 👍 |
16th Oct 2022 8:08am |
16th Oct 2022 2:05pm |
Just as an update, all suspect parts replaced, knocking gone, car drives perfect, thanks for the advice chaps |
25th Oct 2022 8:55pm |
Which parts specifically?
25th Oct 2022 9:02pm |
horse86 Member Since: 09 Dec 2014 Location: PA Posts: 860 |
x2 on which parts? I did all 4 lower control arms and sway arm bushing and end links and still get clunk from front end 2014 FF Autobiography 5.0 SC
31st Oct 2022 6:13pm |
Me too.
31st Oct 2022 6:20pm |
Mine has to be suspension related at I get it when turning to ho over driveway apron on a 45*. I also sometimes get just turning the steering wheel after backing out over the driveway apron when putting it into drive it will clunk starting forward/turning the steering wheel back 2014 FF Autobiography 5.0 SC
31st Oct 2022 7:51pm |
