Home > Maintenance & Mods (L322) > TDV8 inlet hoses....
OK, last question for today...lol...
I take it these hoses are originals so will probably need changing soon at 11 years old...??
Is there a certainty that they will fail? are they a preventative replacement?
Thanks.. Pete
Post #640342 20th Aug 2022 8:58pm
kevinp
I changed mine for some silicone ones just in case after reading the woes of others.
I bought a 500mm length off Amazon so I could make two sets of four so I've got a spare set just in case!! Think it was about £12.
Post #640344 20th Aug 2022 9:25pm
garyRR
There was a topic on this yesterday. The 4x "donut" hoses plus the 2x top charge hoses.
It's pretty common for boost and inlet hoses to begin to fail after 10 years so, yes, preventative maintenance and they probably will fail eventually but may also be good for another 5 years.
They're 70mm internal diameter rubber hose. Pirtek will sell a length cheap if you want to replace them (then just cut the sections you need with a long Stanley blade) or just search ebay.
When you have an inlet leak, you'll most likely get 'Restricted performance' come up under acceleration or, the DPF will soot up prematurely and you'll get the 'DPF Full' amber or red message.
https://www.fullfatrr.com/forum/topic64236-15.html 2015 Range Rover Autobiography 4.4 SDV8
Post #640345 20th Aug 2022 9:26pm
garyRR
Kot wrote:
Do a search on eBay "Silicone Hose Straight Joiner Coupler (Sizes, Colours Available) Black Liner"
Post #640346 20th Aug 2022 9:28pm
You have the original design ones there, genuine replacement set of updated ones from LR is not going to break the bank. They will possibly at some point split, so it’s a good move to swap them to the updated version. Pretty easy job. There is nothing that can't be fixed with a hammer😜😜
Post #640347 20th Aug 2022 9:29pm
garyRR
You've got me curious now. How do you tell what are the originals and what are the updated design? I'll go and have a look tomorrow. 2015 Range Rover Autobiography 4.4 SDV8
Post #640348 20th Aug 2022 10:09pm
Thanks chaps, all good info... Thumbs Up Pete
Post #640349 20th Aug 2022 10:12pm
JayGee
Old ones are moulded rubber (as seen in these pics) and new ones are smooth with white lettering. The rubber material used on the old ones simply disintegrates with prolonged oil contamination. 2012 TDV8 Vogue (L322)
Post #640354 21st Aug 2022 7:56am
Cheers, I'll add them to the list... Thumbs Up Pete
Post #640357 21st Aug 2022 8:29am
Baltic Blue
They were very definitely No 1 fault when I compiled the 44 tdV8 Faul Log
https://www.fullfatrr.com/forum/topic44115...ult+log%2A
Post #640361 21st Aug 2022 8:58am
Baltic Blue
What’s the mileage on your car Pete ?
They have done well to last so long, my first one failed at 43,000 miles., but the modified replacements are still going strong.
Post #640365 21st Aug 2022 9:10am
Thanks Mike, it's done 135,000 but does look in very well kept condition, I've not had it on a ramp yet but what you can see looks better than some I saw with 1/2 the mileage....
I will give it a full service including all fluids so I will have a chance to evaluate it more.... Thumbs Up Pete
Post #640366 21st Aug 2022 9:24am
Pete, contrary to popular belief the original design of your pipes was flat tubing, then JLR replaced them with your current design before returning to flat pipes albeit with a revised part number... Thumbs Up
Post #640374 21st Aug 2022 12:27pm
That explains a lot, cheers, think I'll get some bright green silicone to go with the yellow callipers..... Whistle Shocked Pete
Post #640398 21st Aug 2022 3:21pm
garyRR
So, I just checked and I have the new type with the white writing Thumbs Up 2015 Range Rover Autobiography 4.4 SDV8
Post #640401 21st Aug 2022 3:51pm
