Home > Maintenance & Mods (L322) > TDV8 inlet hoses....
You're sorted for some years then... Thumbs Up Pete
Post #640413 21st Aug 2022 5:15pm
fmgl322
Germany
Evening all,
Does anyone have a part number for the updated LR hoses? Thanks!
Post #641601 31st Aug 2022 10:28pm
MC-RR
Monaco 2012 Range Rover HSE 4.4 V8 Ipanema Sand
Replaced mine last august (2011FF) after one cracked and a second showed heavy wear, mostly around the clamps.(see picture)
Decided to go the silicone direction since they its definitely stronger than factory rubber.
She's been growling beautifully ever since!
As per previous post, from where i was inspired, i used a 70mm silicone hose cut to fit.
best to all,
 RR HSE TDV8 4.4 2012
Jaguar S type 3.6l
Jaguar XJ8
Jaguar X type 3l
Triumph TR6 1976 - Jeep CJ7 1976
Post #641639 1st Sep 2022 10:32am
Keith Moon
2011 Range Rover Vogue SE TDV8 Sumatra Black
Hi MC-RR do you have to remove the donut to replace the hoses? thanks
Post #671501 19th Aug 2023 8:21am
RichTD6
United Kingdom 2012 Range Rover Westminster TDV8 Zermatt Silver
Hi, having replaced mine with silicone ones I can confirm you do need to remove the donut to fit them, or at least get it to a point where you can raise each side enough to slide the old rubbers off and the new ones on.
Rich 2012 Westminster TDV8 4.4 Indus Silver
GAP IID Bluetooth Tool
Previous Range Rovers:
2005 L322 Vogue SE TD6 Zambezi Silver
1995 P38A HSE Epsom Green
1988 Classic Vogue EFi Cassis Red
1973 Two Door Tuscan Blue
Post #671504 19th Aug 2023 9:18am
GraemeS
deleted - already answered...
Post #671505 19th Aug 2023 9:20am
Keith Moon
Many thanks both for quick replies. 👍
Post #671512 19th Aug 2023 10:41am
Baltic Blue
When you see how much “crud” has built up inside, you will want to remove it to clean it out. Thumbs Up
Post #671513 19th Aug 2023 10:51am
MC-RR
HI Keith Moon,
Sorry for the delay in answering, been off driving the "Beast" around Europe.
Yes, must remove the air intake 'donut' which is not complicated. Just a lot of little bolts. Be careful with the plastic hoses and electric connectors.
It will give you a good opportunity to clean the muck inside. Brake cleaner and Mineral spirits work wonders.
Did mine in under 3 hours taking my time.
All the best RR HSE TDV8 4.4 2012
Jaguar S type 3.6l
Jaguar XJ8
Jaguar X type 3l
Post #671821 23rd Aug 2023 9:39am
Keith Moon
thanks - I’ve got the cleaned donut back in situ but struggling a bit to slide the new silicone hoses from the donut across to make the seal - are there any tips on how best to do this? cheers
Post #671880 24th Aug 2023 6:18am
JayGee
Too tight /small or too much friction? Try some silicone spray or grease? 2012 TDV8 Vogue (L322)
Post #671891 24th Aug 2023 7:37am
Keith Moon
all sorted thanks with a bit of perseverance (and a chisel!) - now just waiting for the Araldite to harden on the broken water pipe junction! Big Cry great forum appreciate everyones help/postings Thumbs Up
Post #671935 24th Aug 2023 4:47pm
MC-RR
The infamous water pipe Sad
Well done Smile RR HSE TDV8 4.4 2012
Jaguar S type 3.6l
Jaguar XJ8
Jaguar X type 3l
Post #671942 24th Aug 2023 6:45pm
