![]() | Home > Maintenance & Mods (L322) > TDV8 inlet hoses.... |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8369 ![]() ![]() ![]() |
OK, last question for today...lol...
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 ![]() ![]() |
There was a topic on this yesterday. The 4x "donut" hoses plus the 2x top charge hoses.
2015 Range Rover Autobiography 4.4 SDV8 |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8680 ![]() ![]() ![]() |
You have the original design ones there, genuine replacement set of updated ones from LR is not going to break the bank. They will possibly at some point split, so it’s a good move to swap them to the updated version. Pretty easy job. There is nothing that can't be fixed with a hammer😜😜
You've got me curious now. How do you tell what are the originals and what are the updated design? I'll go and have a look tomorrow. 2015 Range Rover Autobiography 4.4 SDV8 |
Thanks chaps, all good info... |
Old ones are moulded rubber (as seen in these pics) and new ones are smooth with white lettering. The rubber material used on the old ones simply disintegrates with prolonged oil contamination. 2012 TDV8 Vogue (L322) |
Cheers, I'll add them to the list... |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 ![]() ![]() ![]() |
They were very definitely No 1 fault when I compiled the 44 tdV8 Faul Log
What’s the mileage on your car Pete ?
Thanks Mike, it's done 135,000 but does look in very well kept condition, I've not had it on a ramp yet but what you can see looks better than some I saw with 1/2 the mileage....
Pete, contrary to popular belief the original design of your pipes was flat tubing, then JLR replaced them with your current design before returning to flat pipes albeit with a revised part number... |
That explains a lot, cheers, think I'll get some bright green silicone to go with the yellow callipers..... |
So, I just checked and I have the new type with the white writing |
