Home > Maintenance & Mods (L322) > TDV8 inlet hoses.... |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8266 |
OK, last question for today...lol...
20th Aug 2022 8:58pm |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1478 |
There was a topic on this yesterday. The 4x "donut" hoses plus the 2x top charge hoses.
20th Aug 2022 9:26pm |
2015 Range Rover Autobiography 4.4 SDV8 |
20th Aug 2022 9:28pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8611 |
You have the original design ones there, genuine replacement set of updated ones from LR is not going to break the bank. They will possibly at some point split, so it’s a good move to swap them to the updated version. Pretty easy job. There is nothing that can't be fixed with a hammer😜😜
20th Aug 2022 9:29pm |
You've got me curious now. How do you tell what are the originals and what are the updated design? I'll go and have a look tomorrow. 2015 Range Rover Autobiography 4.4 SDV8 |
20th Aug 2022 10:09pm |
Thanks chaps, all good info... Pete
20th Aug 2022 10:12pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3252 |
Old ones are moulded rubber (as seen in these pics) and new ones are smooth with white lettering. The rubber material used on the old ones simply disintegrates with prolonged oil contamination. 2012 TDV8 Vogue (L322) |
21st Aug 2022 7:56am |
Cheers, I'll add them to the list... Pete
21st Aug 2022 8:29am |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3774 |
They were very definitely No 1 fault when I compiled the 44 tdV8 Faul Log
21st Aug 2022 8:58am |
What’s the mileage on your car Pete ?
21st Aug 2022 9:10am |
Thanks Mike, it's done 135,000 but does look in very well kept condition, I've not had it on a ramp yet but what you can see looks better than some I saw with 1/2 the mileage....
21st Aug 2022 9:24am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16298 |
Pete, contrary to popular belief the original design of your pipes was flat tubing, then JLR replaced them with your current design before returning to flat pipes albeit with a revised part number... |
21st Aug 2022 12:27pm |
That explains a lot, cheers, think I'll get some bright green silicone to go with the yellow callipers..... Pete
21st Aug 2022 3:21pm |
So, I just checked and I have the new type with the white writing 2015 Range Rover Autobiography 4.4 SDV8 |
21st Aug 2022 3:51pm |
