Home > Maintenance & Mods (L322) > Front door external window metal trim replacement (How To ?)
Page 1 of 3 123>
ergobyte
France 2012 Range Rover Vogue 4.4 V8 Java Black
Hi,
I have spoted rust on those exterior metal trims framing the window on the front door of my FFRR 2012 vogue.
here is the part I'm talking about
I have ordered one (80€... Censored) but I'd like to know if anyone has done it before ?
any advice welcome
Cheers
Sylvain "it needs some intelligence to undestand you may not have enough"
Post #634386 12th Jun 2022 7:44am
JoolsB
United Kingdom 2012 Range Rover Vogue TDV8 Buckingham Blue
I’ll be interested in this, I didn’t know the part was available. I was looking at it today wondering how I’d paint it!
Let us know how you get on.
Post #634475 12th Jun 2022 8:37pm
ffrr14
Australia 2011 Range Rover Autobiography TDV8 Orkney Grey
Re: Front door external window metal trim replacement (How T
Appears to be a common problem,
Where did you source yours from? SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
New Toy: Unimog U1550L/37
New : G350D
Post #634476 12th Jun 2022 9:13pm
ergobyte
Hi,
I found them on Ebay a seller of OEM LR parts, but not cheap !
https://www.ebay.fr/itm/264857299513?ssPag...2749.l2649
and one in GB
https://www.ebay.fr/itm/333356683252?ssPag...2749.l2649
took me some time to get the right part number though Wink
I really don't know how to tackle tis one, for fear of breaking some thing inside the door, because it plunges in the front...
Still, if any one has clues, I'm a interested !
Cheers
Post #634487 13th Jun 2022 7:05am
Are you sure they are the correct pieces...
Both describe it as FRONT DOOR SEAL UPPER, that to me sounds like the seal at the top of the door, not the metal outside finisher which is what corrodes..?
Worth an email to Duckworths to confirm the part number is correct... Thumbs Up Pete
Post #634494 13th Jun 2022 8:39am
ergobyte
well I already received the parts and they are the right ones (left and right door)
I agree the name is misleading to say the least, but I ordered them with regards to their look and not the reference name, and it worked. I'll upload a picture of the part eventually.
Cheers
Post #634536 13th Jun 2022 4:56pm
ergobyte
There,
Here are the photos of the mystery trim no one ever removed or replaced (so far...)!
with tags an' all
stripped bare !
the narrowest part plunges inside the door to the front.
So, what do you think ?
Cheers
Post #634538 13th Jun 2022 5:32pm
That's good then, just have to work out how to fit them... any clues on the new ones...? Pete
Post #634539 13th Jun 2022 5:33pm
ergobyte
nope,
but there are metal fixtures of sorts all along the interior side of the trim. seem pretty sturdy and willing to give up a fight when tryiong to remove them...
here is a close up
I'm perplexed, it seem really sturdy for light piece of metal to stay in place ? "it needs some intelligence to undestand you may not have enough"
Post #634541 13th Jun 2022 5:42pm
ergobyte
I sincerely hope I won't have to remove the window to fit them in...
I can't believe no one ever changed those mine have their paint all blown by rust.
I can't be the only one, now can I ? I'm going to need mental health support.... Rolling with laughter
Cheers Big Cry
Post #634542 13th Jun 2022 5:47pm
JoolsB
Have you had a look under the door seal? On the parts blow up there seems to be some sort of fixing at the top rear of the window. Also, I wonder if the mirror needs to come off?
Post #634557 13th Jun 2022 8:31pm
Merchy
Firstly, I have not done this job, but I have had the door cards and door mirrors off completely, then you could peel back the insulation ( as in changing door pull cables ) and see where the part goes into the door, and see if there are any fastenings, not a real answer but hope this helps a bit. Access this way MAY make the job easier.
Door cards are quite easy to remove as you probably already know.
Post #634560 13th Jun 2022 9:11pm
ergobyte
Thanks you all,
Merchy --> I've had prior bad experiences with door cards, on other makes and models, as clips blow and pieces gets torn,...
I'll check in the wiki for the proper procedure first.
JoolsB --> I'll look for that first fixing to remove, as it could be the lock for the whole thing to be easily removed (I wish).
I'll be back at you guys
Cheers
Post #634580 14th Jun 2022 8:19am
Merchy
Below are two videos for removal and fitting of the door cards, quite easy especially if you have a car trim kit of tools ( Quite cheap and very handy ) Mine have been off several times, never had any clips break at all.
Hope this helps Thumbs Up
https://www.google.com/url?esrc=s&q=&a...TtidBOunVC
https://www.google.com/url?esrc=s&q=&a...A3RSzVMcL6
Post #634581 14th Jun 2022 8:38am
ergobyte
great
seem simple enough Wink
Many thanks
cheers Thumbs Up
Post #634585 14th Jun 2022 8:49am
Page 1 of 3 123>
