![]() | Home > Maintenance & Mods (L322) > Front door external window metal trim replacement (How To ?) |
Googs Member Since: 19 May 2022 Location: Tassie Posts: 158 ![]() ![]() |
It’s hard to believe that no one else on this form has removed any parts like this before, good luck 🤞 |
ergobyte Member Since: 03 Apr 2022 Location: bordeaux Posts: 124 ![]() ![]() ![]() |
especially if they rust, I can't believe i'm the only one... that would be such bad luck |
Can you post photo of the affected one on your RR ? |
will get a picture tomorow at sun up (I mean when I'll wake up...) ! "it needs some intelligence to undestand you may not have enough" |
Ok, that will be good….help me understand exactly where they are supposed to fit.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8559 ![]() ![]() ![]() |
It's the exterior black frame at the top of the doors, the early ones like yours didn't rust as much as the later ones, my 2002 was mint, my 2012 was rusty...!!! |
Ok Pete thanks.
Here are the close-ups
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 911 ![]() ![]() ![]() |
I wonder if you could carefully mask it off & re-paint in situ? |
I can see the problem….steering wheel on wrong side🤣🤣.
I know, but
IMHO waste of time trying to repaint that, the corrosion is coming from the back, around to the front, unless you took them off and got all the corrosion front and back off you are flogging a dead fatty, it will come back straight away... |
Nah,
Out of sight, out of mind...lol.... |
