![]() | Home > Maintenance & Mods (L322) > Front door external window metal trim replacement (How To ?) |
JoolsB Member Since: 16 Aug 2020 Location: The North Posts: 296 ![]() ![]() ![]() |
I’ll be interested in this, I didn’t know the part was available. I was looking at it today wondering how I’d paint it!
ffrr14 Member Since: 21 Apr 2021 Location: Sydney Posts: 187 ![]() ![]() ![]() |
Appears to be a common problem,
ergobyte Member Since: 03 Apr 2022 Location: bordeaux Posts: 124 ![]() ![]() ![]() |
Hi,
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8560 ![]() ![]() ![]() |
Are you sure they are the correct pieces...
well I already received the parts and they are the right ones (left and right door)
There,
That's good then, just have to work out how to fit them... any clues on the new ones...? Pete
nope,
I sincerely hope I won't have to remove the window to fit them in...
Have you had a look under the door seal? On the parts blow up there seems to be some sort of fixing at the top rear of the window. Also, I wonder if the mirror needs to come off? |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1236 ![]() ![]() ![]() |
Firstly, I have not done this job, but I have had the door cards and door mirrors off completely, then you could peel back the insulation ( as in changing door pull cables ) and see where the part goes into the door, and see if there are any fastenings, not a real answer but hope this helps a bit. Access this way MAY make the job easier.
Thanks you all,
Below are two videos for removal and fitting of the door cards, quite easy especially if you have a car trim kit of tools ( Quite cheap and very handy ) Mine have been off several times, never had any clips break at all.
great
