Home > Maintenance & Mods (L322) > 2012 tdv8 oil cooler
sean mullane
Ireland
I fitted a new oil cooler 2 months ago , it appears to be leaking again , anyone got any idea what could have be wrong . Thank you
Post #634256 10th Jun 2022 12:02pm
Baltic Blue
Why do you think it is leaking ?
If it is drips on the floor, did you remove and clean the undertray ?, they can take ages to stop leaving drip marks if you didn’t.
Post #634260 10th Jun 2022 12:28pm
sean mullane
Ireland
Smoke coming up around the oil filter and faint traces of oil in the coolant
Post #634262 10th Jun 2022 1:16pm
JMC
There are two distinct areas of potential leakage. Around the oil cooler via the main gaskets, or the oil feed pipe via (2) perished O-rings.
When you changed it a couple of months ago, did you fit new gaskets and O-rings? Also, did you fit a genuine unit, or was it one of the cheap aftermarket ones? The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #634264 10th Jun 2022 2:18pm
sean mullane
Ireland
Cooler is made by nissens, it came with new gaskets , o rings were not changed but don’t appear to be leaking
Post #634268 10th Jun 2022 3:10pm
JMC
I do wonder about the aftermarket quality - especially the supplied gaskets.
LR have actually made new gaskets with different part numbers from the original ones, presumably to help cure the problem of failure.
I also bought a complete top hose before tackling the job, but didn't need it in the end. Handy to have a spare though!
The oil cooler gaskets are now # LR077242 & LR022903. I'd also suggest the replacing the original feed pipe O-Rings with Victon BS611 O-Rings is an absolute no-brainer at the same time.
I didn't change the cooler itself - just the gaskets and O-rings. Six months later with 5k miles done and the cooler area is still clean as a new whistle. The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #634283 10th Jun 2022 4:59pm
garyRR
I too also thought the issue was perished rubber seals and o-rings, not the actual oil cooler. 2015 Range Rover Autobiography 4.4 SDV8
Post #634284 10th Jun 2022 5:05pm
mjdronfield
I understand the cooler can warp sometimes. The garage that did mine said they had also seen coolers that had cracked.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #634290 10th Jun 2022 5:29pm
Dolphinboy
Wot MJD said. My cooler had warped slightly as they are 2 parts and weren't sitting correctly so leaked out.
Post #634293 10th Jun 2022 5:47pm
