Home > Maintenance & Mods (L322) > 2012 tdv8 oil cooler
sean mullane
Ireland
I fitted a new oil cooler 2 months ago , it appears to be leaking again , anyone got any idea what could have be wrong . Thank you
Post #634256 10th Jun 2022 12:02pm
Baltic Blue
Why do you think it is leaking ?
If it is drips on the floor, did you remove and clean the undertray ?, they can take ages to stop leaving drip marks if you didn’t.
Post #634260 10th Jun 2022 12:28pm
sean mullane
Ireland
Smoke coming up around the oil filter and faint traces of oil in the coolant
Post #634262 10th Jun 2022 1:16pm
JMC
Scotland 2012 Range Rover Westminster TDV8 Orkney Grey
There are two distinct areas of potential leakage. Around the oil cooler via the main gaskets, or the oil feed pipe via (2) perished O-rings.
When you changed it a couple of months ago, did you fit new gaskets and O-rings? Also, did you fit a genuine unit, or was it one of the cheap aftermarket ones? The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #634264 10th Jun 2022 2:18pm
sean mullane
Ireland
Cooler is made by nissens, it came with new gaskets , o rings were not changed but don’t appear to be leaking
Post #634268 10th Jun 2022 3:10pm
JMC
I do wonder about the aftermarket quality - especially the supplied gaskets.
LR have actually made new gaskets with different part numbers from the original ones, presumably to help cure the problem of failure.
I also bought a complete top hose before tackling the job, but didn't need it in the end. Handy to have a spare though!
The oil cooler gaskets are now # LR077242 & LR022903. I'd also suggest the replacing the original feed pipe O-Rings with Victon BS611 O-Rings is an absolute no-brainer at the same time.
I didn't change the cooler itself - just the gaskets and O-rings. Six months later with 5k miles done and the cooler area is still clean as a new whistle. The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #634283 10th Jun 2022 4:59pm
garyRR
I too also thought the issue was perished rubber seals and o-rings, not the actual oil cooler. 2015 Range Rover Autobiography 4.4 SDV8
Post #634284 10th Jun 2022 5:05pm
mjdronfield
I understand the cooler can warp sometimes. The garage that did mine said they had also seen coolers that had cracked.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #634290 10th Jun 2022 5:29pm
Dolphinboy
Wot MJD said. My cooler had warped slightly as they are 2 parts and weren't sitting correctly so leaked out.
Post #634293 10th Jun 2022 5:47pm
