Home > Maintenance & Mods (L322) > 2012 tdv8 oil cooler |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3763 |
Why do you think it is leaking ?
10th Jun 2022 12:28pm |
sean mullane Member Since: 10 Dec 2019 Location: limerick Posts: 18 |
Smoke coming up around the oil filter and faint traces of oil in the coolant |
10th Jun 2022 1:16pm |
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 755 |
There are two distinct areas of potential leakage. Around the oil cooler via the main gaskets, or the oil feed pipe via (2) perished O-rings.
10th Jun 2022 2:18pm |
Cooler is made by nissens, it came with new gaskets , o rings were not changed but don’t appear to be leaking |
10th Jun 2022 3:10pm |
I do wonder about the aftermarket quality - especially the supplied gaskets.
10th Jun 2022 4:59pm |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1463 |
I too also thought the issue was perished rubber seals and o-rings, not the actual oil cooler. 2015 Range Rover Autobiography 4.4 SDV8 |
10th Jun 2022 5:05pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7788 |
I understand the cooler can warp sometimes. The garage that did mine said they had also seen coolers that had cracked.
10th Jun 2022 5:29pm |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3136 |
Wot MJD said. My cooler had warped slightly as they are 2 parts and weren't sitting correctly so leaked out. |
10th Jun 2022 5:47pm |
