Home > Maintenance & Mods (L322) > Service manual 2006 AJV8 |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1192 |
Check out the 'Wiki' section, scroll down to the 'Info' section and you will find service schedule sheets, plus oil service schedules for different models.
4th Mar 2022 12:03am |
Grayson Welly Member Since: 05 Sep 2021 Location: SW20 Posts: 95 |
Thanks a lot. I've looked in the wiki and there is actually very little on the AJV8 4.4L -- however, there is an incredible resource in the 06-10 Workshop Manual, form which I've learnt that my engine is actually an AJ41!.
4th Mar 2022 11:57am |
Is the AJ48 4.2L Supercharged the same specification for oil capacity and spec as the AJ41 4.4L V8? --------
4th Mar 2022 1:45pm |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2215 |
Afaik it’s slightly bigger capacity but is missing the blower aside from that there are lots of similarities so I’d imagine so Current stable:
5th Mar 2022 10:41am |
mark towill Member Since: 27 Aug 2020 Location: calgary Posts: 19 |
The exact capacity of my AJ41 is 7.7 litres including filter. Do not know if you have WIX filters in the UK but it is #57302 and I use 5W30 synthetic oil in the winter here works great in 08 RR lux as my snow car. Hope this helps |
6th Mar 2022 2:51am |
Winkelried Member Since: 14 Aug 2016 Location: UR Posts: 7 |
Owning a 2006 MY myself, I know about the PITA about the right WSM. The 2006 isa transition model - at least mine is one. So I check the 2006-2010 WSM first and then the 2002-2005 to get an idea.
20th Mar 2022 9:30pm |
