![]() | Home > Maintenance & Mods (L322) > Service manual 2006 AJV8 |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1222 ![]() ![]() ![]() |
Check out the 'Wiki' section, scroll down to the 'Info' section and you will find service schedule sheets, plus oil service schedules for different models.
Grayson Welly Member Since: 05 Sep 2021 Location: SW20 Posts: 95 ![]() ![]() |
Thanks a lot. I've looked in the wiki and there is actually very little on the AJV8 4.4L -- however, there is an incredible resource in the 06-10 Workshop Manual, form which I've learnt that my engine is actually an AJ41!.
Is the AJ48 4.2L Supercharged the same specification for oil capacity and spec as the AJ41 4.4L V8? --------
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2218 ![]() ![]() ![]() |
Afaik it’s slightly bigger capacity but is missing the blower aside from that there are lots of similarities so I’d imagine so Current stable:
mark towill Member Since: 27 Aug 2020 Location: calgary Posts: 19 ![]() ![]() ![]() |
The exact capacity of my AJ41 is 7.7 litres including filter. Do not know if you have WIX filters in the UK but it is #57302 and I use 5W30 synthetic oil in the winter here works great in 08 RR lux as my snow car. Hope this helps |
Winkelried Member Since: 14 Aug 2016 Location: UR Posts: 7 ![]() ![]() ![]() |
Owning a 2006 MY myself, I know about the PITA about the right WSM. The 2006 isa transition model - at least mine is one. So I check the 2006-2010 WSM first and then the 2002-2005 to get an idea.
