![]() | Home > Technical (L405) > ABS Module fault? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35542 ![]() ![]() |
you told it that you have fitted a new battery?
Martyn Member Since: 10 Mar 2013 Location: Poole Posts: 65 ![]() ![]() |
Hi Stan, I did indeed.
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1293 ![]() ![]() |
Charge the battery and check all terminals are tight? 2018 SE SDV8 4.4 Byron Blue |
I'll chuck it on the CTEK in AGM mode over night, I don't hold out much hope though as even with the CTEK in supply mode it didn't make any difference.
There is also the mystical touch + and - together with the battery out, but with secondary batteries etc I dont have the |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3204 ![]() ![]() |
I had this on my 2004. All the lights went on. Went to LR and they said "oh yes sir, needs new ABS module - that'll be £1000.
CTEK is on the car again, no change.
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1796 ![]() ![]() |
Check the earth terminal in the front OS wheel arch. Known to cause ABS faults when corrosion sets in |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2595 ![]() ![]() |
mythical - it achieves nothing. |
Oooh Mikey could be on to something here!
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 664 ![]() ![]() ![]() |
How do you get to this, looks like something that should be cleaned up and given a generous coating of ACF50 before it gets this far? Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
It's behind the front right wheel arch liner, here:
I’ll add that to the summer maintenance checks.
Not going to say its a common issue, but its not the first one we've repaired |
